Front swaybar bushing replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by kittyhawk, Nov 5, 2020.
  1. Nov 5, 2020 at 10:49 AM
    kittyhawk
    kittyhawk [OP] New Member
    Dave
    2013 4Runner SR5
    None
    Hi everyone, I've got a eibach pro kit ordered and was under the truck this morning and noticed the front swaybar bushings were getting a little warn and squeeking when pushing up and down on the front bumper. So my question is should I go back with factory rubber or go with poly ones? Also since I'm doing the work should I do the rears at the same time?
    Thanks in advance
  2. Nov 5, 2020 at 10:54 AM
    CowboyTaco
    CowboyTaco New Member
    Michael
    2011 Tacoma DCSB
    My opinion is that typically it is best to go with OEM, but how many miles do you have on your truck? It's not overly common for those to wear out, though all bushings will wear out over time.
    Depending on your use, you may consider the Energy Suspension replacements. The black ES bushings are graphite impregnated.
  3. Nov 5, 2020 at 11:03 AM
    wmdtech
    wmdtech Send MOD Money!!
    Nate
    Mid TN
    18 TRD ORP
    I replaced mine when doing the stage 1. Went with Prothane and no real complaints. All I will say is that the grease point for the rear bushing on the driver side is hard to get to due to the gas tank.
  4. Nov 5, 2020 at 11:17 AM
    kittyhawk
    Dave
    2013 4Runner SR5
    None
    Thanks guys, the truck has 145,xxx miles on her. I'll call around get the best prices on the OEM bushing. Yes the rear did look to be a bugger to get replaced but ill manage.
