Front Strut / Shock advice
Discussion in '3rd Gen 4Runners (1996-2002)' started by obx4runner, Nov 24, 2020.
  1. Nov 24, 2020 at 3:51 PM
    obx4runner
    obx4runner [OP] New Member
    My 2002 4runner with 102K miles has the original struts/shocks. What would you experts recommend as replacements ? also...should I get the front end aligned after I replace them ? Thanks !!
  2. Nov 24, 2020 at 3:54 PM
    It depends on what kind of ride you're after.
    If you like the way it rides stock, then go for a stock replacement.
    If you think it could handle better with a slightly firmer shock, try a bilstein 5100.
    Yes, you will need an alignment after replacing suspension components.
    obx4runner[OP] likes this.
  3. Nov 24, 2020 at 4:06 PM
    obx4runner
    I was thinking that the ride / handling could be a little better with more modern/better quality strut/shock. I imagine most would upgrade from stock. thanks for the advice.
    nimby[QUOTED] likes this.
  4. Nov 24, 2020 at 7:53 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    replace with OEM...unless you're looking to upgrade...and get a alignment....it will be needed
  5. Nov 24, 2020 at 9:01 PM
    This is my 2002 with Bilstien 5100’s set at 2” with Falken 265/75/16 MT’s handled great. Sold it damit.
    nimby likes this.
