Front seat!!!
Discussion in '2nd Gen 4Runners (1990-1995)' started by Ninety2Door, Jul 15, 2023.
  1. Jul 15, 2023 at 2:41 AM
    Ninety2Door
    Ninety2Door [OP] New Member
    Red/Grey 1990 2-Door 4RUNNER 4X4 V6 Auto
    Hello ToyHeadz,
    Sooooo, I took my front passenger seat out for a camping trip (to make room for gear) and upon reinstall I wasn't able to get the two front bolts to align to save the life of me. WTF?!
    I was super careful with the the seat after removal, but now the damn holes won't align.
    Anyone know of a trick?
    All the best,
    Ninety2Door
  2. Jul 15, 2023 at 7:17 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Hmmm, I just had my front seat out doing a stereo install. I didn't notice any issues. I did install the rear forst and then the front. If you do that, the front legs have some movement if you just grab ahold of them and squeeze together or pull apart as needed.
    Tama1968 and Ninety2Door[OP] like this.
  3. Jul 15, 2023 at 7:24 AM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    Do you have the pins on the bottom of the rails lined up and sunk into the floor holes?
  4. Jul 15, 2023 at 10:23 AM
    Oakboro, N.C
    Check to make sure the adjuster did not accidentally slide on one side more than the other.
    I would also make sure not to tighten the bolts too much initially to give a little room for movement when installing the remaining bolts.
    If you can then get them all in, Shift the seat around to settle it and then slowly tighten the mounting bolts up.
    kingroon and Ninety2Door[OP] like this.
  5. Jul 15, 2023 at 4:17 PM
    Ninety2Door
    Tried that, but the front holes won't lineup
  6. Jul 16, 2023 at 12:19 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Did you get it figured out? Often one side of the slider can move while the other did not. So you gotta hold the adjuster and push on one slider only.
  7. Jul 16, 2023 at 12:59 AM
    Ninety2Door
    Haven't figured it out yet. I put it on the backburner....as I never really have a passenger that doesn't think it's cool to have 5' of leg room .
    But eventually I'll want to reinstall it. Never had this problem with any of my other Toyz.
  8. Jul 16, 2023 at 8:11 AM
    Oakboro, N.C
    Well keep us updated in regards to what you find when you go back to tackling this issue.
  9. Jul 16, 2023 at 1:16 PM
    Ninety2Door
    Will do! Thanks for all yalls input.
