Front Hydraulic Bump Stops
Discussion in '5th Gen 4Runners (2010-2024)' started by n8th8n, Feb 11, 2024.
  1. Feb 11, 2024 at 10:36 PM
    n8th8n
    n8th8n [OP] New Member
    5th Gen 4Runner
    Mid Travel with King Shocks and Dirt King Uppers
    Hello everyone! I am possibly looking into hydraulic bump stops for the front to help with less up travel and bottoming out. Does anyone here by any chance have any experience or knowledge on how these would be mounted and installed? I couldn't find any kits or brackets to be purchased online anywhere, I'm assuming these would have to be customer welded with the cans from king or what not to the stock factory lower control arm location. Thank you all!
  2. Feb 12, 2024 at 12:55 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Please please please post videos of you jumping.
  3. Feb 12, 2024 at 2:47 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    will work just fine. Hydro bumps are not an easy installation and expensive.
  4. Feb 12, 2024 at 7:15 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    VIDEOS OF JUMPING! OR IT NEVER HAPPENED!
    raimieb and MI-FL off roader like this.
  5. Feb 12, 2024 at 7:22 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    No they wont. Claims to jump his 4R and do "fast pre-runner" stuff. Not some rock crawling bullshit. (His words)
  6. Feb 12, 2024 at 8:19 AM
    Someone would have to fab up a mount on the frame and it would be better with aftermarket LCAs like:
    I was that guy too in my Tacoma but really you don't have a trophy truck. Especially with this fat pig, you will quickly break the upper coilover mounts, inner fender structure and radiator core support. I'd work on better dampening like a bypass as well.
    MI-FL off roader likes this.
  7. Feb 12, 2024 at 8:25 AM
    n8th8n
    5th Gen 4Runner
    Wow this is beautiful... Yeah, I kind of over estimated how much only a mid travel could do on a car, and as of now I am just trying to figure out some good bump stops to limit some up travel and start taking it easy a bit more, and then think about a full long travel kit in the near future. Appreciate the help :D
  8. Feb 12, 2024 at 8:47 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    They work, not for TT shit, but they work. If OP is bouncing off the factory pucks, these will be a vast improvement in the short term. A lot of the Taco LT boys use them or Duros on the front suspension because hydros can interfere with shock damping in the last several inches of travel, and then your tuning bumps AND your COs. Super Bumps are less likely to do that and a much easier install. This Video was taken before I revalved my rear smoothies. They were way too soft, but as you can see, those big hunks of Rubber can take some abuse. The one downside is they will get dry and crack after awhile in the desert climates.
    https://youtu.be/OoJUF02t4bo?si=IquP11BZJl_nK7PH
    hossler1788 likes this.
  9. Feb 12, 2024 at 9:26 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
  10. Feb 12, 2024 at 9:37 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    @MI-FL off roader Nice build. Attention to detail and safety are super important if you're going this route. Looks like you've got both.
  11. Feb 12, 2024 at 11:00 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    Thank You, it's actually not as safe as it should be, needs a cage....and I don't even jump it...well not much and not very high.....
    catbrown357[QUOTED] likes this.
  12. Feb 12, 2024 at 3:50 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Dammit, I missed all the fun......must have been edited ;)
  13. Feb 12, 2024 at 5:37 PM
    catbrown357
    Tempe
    2011 Limited 4WD
  14. Feb 12, 2024 at 6:02 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
