Front Hub Dust Cap? RESOLVED
Discussion in '5th Gen 4Runners (2010-2024)' started by laxman09, Feb 24, 2024.
  1. Feb 24, 2024 at 5:44 AM
    laxman09
    laxman09 [OP] Gassy Member
    Mahoning Valley, OHIO
    Currently at the shop getting my new style TRD Pro wheels put on my 2020 SR5P. Guy comes back and says there's an issue and we go back and he shows me how the wheel won't seat with the front hub dust cap on but does seat fine with it off. I told him to leave it off and that my center caps will cover it when they hopefully arrive this week.
    Now I'm wondering, is there a problem with this? Are there different part # dust caps that work for the newer TRD Pro wheels that I should pick up? Thanks.
  2. Feb 24, 2024 at 6:41 AM
    TrailSpecial22 New Member
    PA
    id say dust caps are there for a reason. I personally, would not run my 4runner without it
  3. Feb 24, 2024 at 6:43 AM
    laxman09
    The wheel wouldn't seat with it on. I'm wondering if the part changed a bit. Once it was off it seated perfectly
  4. Feb 24, 2024 at 6:50 AM
    PA
    sounds like a wheel issue not being correct for the 4runner. Hopefully someone with your rims will weigh in on this thread
  5. Feb 24, 2024 at 6:51 AM
    laxman09
    They are oem trd pro wheels. The new version. Bought from Toyota dealership
  6. Feb 24, 2024 at 6:53 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Yeah...That's a bad idea. The center bore on those wheels must be slightly different. I'd start looking into that before risking potentially expensive damage.
  7. Feb 24, 2024 at 6:56 AM
    laxman09
    Yeah I'm kinda at a loss. I remember reading threads about the impossible to find new center caps and seeing people with the new style wheels on and seeing the front hub in the middle.
  8. Feb 24, 2024 at 7:00 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Why not return the wheels due to non-fitment? If they don't fit, they don't fit. There's plenty of nice wheels that do.
    JChiz and TrailSpecial22 like this.
  9. Feb 24, 2024 at 7:05 AM
    laxman09
    Bc they are already on :anonymous:
    The rears went on no problem.
  10. Feb 24, 2024 at 7:12 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Did you change anything on the front? It looks like maybe new rotors? Or did you have them resurfaced?
  11. Feb 24, 2024 at 7:14 AM
    laxman09
    Didn't touch them. Bought it CPO in December 23
  12. Feb 24, 2024 at 7:20 AM
    PA
    I’ll go back to the Toyota dealership and have one of their techs look at
    JChiz likes this.
  13. Feb 24, 2024 at 7:20 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Hub bore should be 106.1mm. Something's off. Especially since the rears fit. 4Runners are hubcentric. Any wheel with a 106.1mm bore should fit with no modifications. Since the rotors look either new or resurfaced, I would question the dealer on that. Making sure the wheels have the correct bore of course.
  14. Feb 24, 2024 at 7:21 AM
    laxman09
    I didn't buy them locally. Dealership I got them from is a few hours away.
  15. Feb 24, 2024 at 7:23 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    CAVEAT EMPTOR.
  16. Feb 24, 2024 at 7:26 AM
    laxman09
    Idk how much more legit I could have got than buying OEM wheels direct from a dealership
  17. Feb 24, 2024 at 7:27 AM
    PA
    rears won’t be a problem because there’s no dust cap.
  18. Feb 24, 2024 at 7:28 AM
    laxman09
    Yes that I know, but I do appreciate you confirming it.
  19. Feb 24, 2024 at 7:32 AM
    PA
    Hey reach out to one of these members looks like he’s got the same rim and on a 2021. Maybe he can assist to see what he has underneath the rim as far as the dust cap design
  20. Feb 24, 2024 at 7:34 AM
    laxman09
    Ok went out and felt where the hub/wheel meet. It feels seamless. No gaps or anything. Completely aligned.
    The grease cap looked to fit OVER the hub when they took off my SR5 wheels. That's why I'm wondering if there is a new grease cap that fits differently
  21. Feb 24, 2024 at 7:39 AM
    laxman09
    He hasn't been online since 2022 unfortunately
  22. Feb 24, 2024 at 7:47 AM
    4runningMan
    4runningMan New Member
    New Mexico
    If I remember correctly, the plastic cap pops into the new pro wheels from the back. Unlike the older pro wheel where the cap pops on from the front. Thus, you have to remove the wheel to install the cap.
    I don’t know if this is related to your issue.
  23. Feb 24, 2024 at 7:48 AM
    4runningMan
    New Mexico
    That wheel is different than OP’s.
  24. Feb 24, 2024 at 8:05 AM
    laxman09
    Here is what I was told was the problem. This flange wouldn't let it seat correctly.
    I also called the dealership I bought them from and they said call back Monday when their lead tech is in.
    4runningMan and TrailSpecial22 like this.
  25. Feb 24, 2024 at 8:15 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    That flange should be the same diameter as the bore on the hub. Again, something changed either on the wheels or the hub. Hope you can get it sorted out on Monday.
  26. Feb 24, 2024 at 8:20 AM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    2024 4Runner OR Solar Octane
    I posted in the other thread but I have a 2021 ORP with these same wheels and they fit with zero issues, run them for over 30,000km. I went out and took a picture of my hubs. They currently have 17" FJ Cruiser steel winter wheels on but you can see the dust cap and hub which have zero issues accepting the new style TRD Pro wheels.
    catbrown357 likes this.
  27. Feb 24, 2024 at 8:24 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Nice. Thanks. I would have done the same, except I have center caps on my wheels that prevent me from seeing the hubs unless I remove the wheel.
  28. Feb 24, 2024 at 8:31 AM
    laxman09
    Heading to my local dealership for them to take a look at as they are unsure of what the issue could be.
  29. Feb 24, 2024 at 8:35 AM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Just spitballing but you said you bought it CPO, could it previously have had the hubs replaced with non oem for some reason?
  30. Feb 24, 2024 at 8:38 AM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: Hefty and Bud Built. Tires: KM3. Switchpro.
    Often when they are removed, the chiseling on the edge damages the dust caps. Perhaps they got bent up a little and no longer fit within the original diameter? Not a bad idea to buy a few extras - I carry spares so that if I punch through the caps when making a trail repair, I can just use a new one if needed.
    TrailSpecial22 and laxman09[OP] like this.
