Front end grind
Discussion in '3rd Gen 4Runners (1996-2002)' started by JC520, Jan 30, 2020.
  1. Jan 30, 2020 at 1:44 PM
    JC520
    JC520 [OP] New Member
    1997 4Runner SR5
    97 SR5 w/ 185K is grinding behind passenger front wheel when turning in either direction. First thought is bearings, but have since been reading about issues with the ball joints. Anyone have this issue in the past or know what I could be looking at? Picked this up for my son and have nothing but issues ever since.
  2. Jan 30, 2020 at 4:32 PM
    Ball joints are a known issue, and welcome to the forum.
  3. Jan 31, 2020 at 6:45 AM
    Man, bearings on these things are massive. Not saying they never go bad but I wouldn't think 185k is enough to wear one out. 185k miles is enough to need ball joints though.
    I had 250k on my 2002 before I swapped upper and lower ball joints. I had the steering knuckle off and the wheel bearings had no play in them whatsoever.
    Is this a 4x4 rig? Grinding when you turn the wheel stopped or only when driving?
    I thought Ball Joints will generally exhibit bad behavior when going over bumps (vertical travel). Not really a grinding. I would suspect something that moves with the wheel or front axle if you have a 4x4.
  4. Jan 31, 2020 at 7:13 AM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    I would check your half shafts if it's 4x4. I've had them make some racket when they go bad. Especially lower speed turns like pulling into parking spots.
  5. Jan 31, 2020 at 12:41 PM
    4x Old Guy
    4x Old Guy New Member
    Riverside, CA
    Big-O Bigfoot A/T tires
    I concur. CV joints will go bad over time (especially if the truck’s been lifted).
