Front driver side door actuator
Discussion in '5th Gen 4Runners (2010-2024)' started by AlexM102017, Feb 5, 2020.
  1. Feb 5, 2020 at 6:05 AM
    AlexM102017
    AlexM102017 [OP] New Member
    Alex
    2014 4Runner Limited
    None
    Has anyone had to replace their driver side door lock actuator? If so did you buy the part online? Also if you did who did you buy from and is it good?
  2. Feb 5, 2020 at 11:43 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
  3. Feb 5, 2020 at 11:48 AM
    AlexM102017
    Alex
    None
    @j cat Its a 2014 limited
  4. Feb 5, 2020 at 12:11 PM
    j cat
    j cat New Member
    massachusetts
    not common on your DOM.. is it extreme cold out ? possible water got into it and iced it up..
    rockauto has them on the cheap.... 35 bucks. the cause is water intrusion .. check window seals for damage / shrinking etc...
    some did replace the motor that moves the locker. about 9 bucks ..
  5. Feb 5, 2020 at 12:48 PM
    AlexM102017
    Alex
    None
    @j cat i live in Florida so no cold weather. I’ve looked online but I hear a lot of the brands out aren’t good.
  6. Feb 5, 2020 at 12:49 PM
    AlexM102017
    Alex
    None
    @j cat also I’m hoping it is just the actuator. I have keyless entry and that’s the only door that doesn’t unlock.
  7. Feb 5, 2020 at 1:12 PM
    j cat
    j cat New Member
    massachusetts
    well in florida it is a water corrosion issue. limited has auto locks no key control. It is a PITA to get in. I am in naples now. I do not wash my runner with tap water..
  8. Feb 6, 2020 at 9:50 AM
    4RunnerBoss
    4RunnerBoss New Member
    Got an OEM actuator from https://www.toyotapartsdeal.com/ without any issues. They processed and shipped my order fast too.
  9. Feb 6, 2020 at 10:19 AM
    j cat
    j cat New Member
    massachusetts
    I did buy parts from that website .. fast delivery ..
    4RunnerBoss[QUOTED] likes this.
