Front bumper gaps
Discussion in '5th Gen 4Runners (2010-2024)' started by HighSierraGuy, Dec 4, 2024.
  1. Dec 4, 2024 at 12:26 PM
    HighSierraGuy
    HighSierraGuy [OP] New Member
    Has anyone had any success in keeping these gaps tighter? The one on the corner seems to not stay clipped in and the other one is a larger gap than the opposite side. I'm taking my bumper off this weekend to install some headlamps and figured I'd check if anyone has a fix for this.
    Thanks
    andrewtheadventurer likes this.
  2. Dec 4, 2024 at 1:01 PM
    There have been several threads about this same issue. Sorry to say, no one has come up with a definitive fix. If the photos you posted look off to you, I've seen worse, I guarantee you. My passenger side beneath the headlight will also not stay up tight. I have been searching for a fix for a couple years.
    https://www.4runners.com/threads/front-bumper-separation-gap.14594/
    https://www.4runners.com/threads/gap-in-front-bumper-any-reliable-fix.33383/
    Would you do me a favor - when you have the bumper cover off, could you snap some photos of the back side of the bumper cover, right where that corner is below the headlight, and also some pictures of the clips on the body under the headlight where the bumper cover snaps into? I would appreciate it, thanks.
    I wish I had better information for you. You'll see my username in the above threads looking for a solution, just like you are now...
  3. Dec 4, 2024 at 1:56 PM
    HighSierraGuy
    Thanks for bumping that other thread. Yea sure thing, it'll be a week or so before I'll get to it but will try and take some pics.
  4. Dec 4, 2024 at 2:25 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    The bumper clips into a black plastic piece on both sides. These are fastened to the body using a bolt in a slightly oversized hole. That oversized hole allows for some adjustment.
    If you can't get it high enough, oversize the hole more and use a washer to keep it secure. Should be able to tighten that up quite a bit.
    Saker likes this.
  5. Dec 4, 2024 at 2:30 PM
    Speaking from experience?
    Saker likes this.
  6. Dec 4, 2024 at 2:39 PM
    1SilverRunner
    Tejas
    Yes you can make some play in those retainers. I think there are two clips and one hole. Although I cant remember if the hole that you can oversize is under the headlight or next to the fender. I want to say its on the fender side, but it's been about a year since I fiddled with this.
    Saker likes this.
  7. Dec 4, 2024 at 6:31 PM
    andrewtheadventurer
    I have the same issue. Op if you do this, please post pics
    HighSierraGuy[OP] likes this.
  8. Dec 5, 2024 at 5:54 AM
    Thank you. It will clarify, perhaps, what @1SilverRunner is referring to - the bumper cover attachment clips mounted on the body, and which is the one that can be adjusted to help tighten up that part of the cover to (hopefully) keep it in place.
    Saker and 1SilverRunner like this.
  9. Dec 6, 2024 at 11:10 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I had some minor collision repair done to the driver side headlight area and afterward that plastic bumper cover kept popping out every day or so. The clipping system just would not stay engaged. So I pulled back the cover a little and squirted some clear E6000 hobby glue (with a pointed nozzle) into that clip area. Then pushed it into place and taped it over with a strong duct tape. After a couple of days to cure I carefully removed the tape so as not to tug on the joint. It’s been over 4 months and all is well.
    If I ever need to remove the head light I’ll just have to take more care to break or cut out that glue blob.
  10. Dec 6, 2024 at 11:48 AM
    That is one solution. I may end up there some day.
