From stock 22 ORP to Moab-ready for $2,500?
Discussion in '5th Gen 4Runners (2010-2024)' started by Wildfish, May 20, 2024.
  1. May 20, 2024 at 8:17 AM
    Wildfish
    Wildfish [OP] New Member
    2022 4Runner TRD Off-Road
    Hi all,
    Just got my first 4Runner, which has been something of a dream vehicle for me for a long time. Ended up with the 2022 TRD Off Road Premium. I'm a little jealous of the Pro's 1" lift and suspension, but couldn't swing the 10k premium.
    I'm coming from a lifted Subaru outback that was, frankly, pretty nimble off road. But I'm now planning a cross country trip to UT and WY, including a stop in Moab, some fly fishing in the mountains, and then Colorado on the way home.
    I'm bone stock now. If I can only manage about $2,500 in upgrades before the trip, what is "essential?" I already have some recovery gear (Maxxtrax, tow straps, soft shackles, etc). I definitely need new tires. Hoping not to kill the MPG and road noise, though I have enjoyed Faulkan Wildpeak AT3s in the past.
    Part of me thinks maybe just do the new shoes and get an internally mounted compressor for airdowns and save the money for gas. I won't be doing Hell's Revenge, but I also don't want to say "damn it! If only I had a 2" lift I could have done XXX."
    Thoughts?
  2. May 20, 2024 at 8:20 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    New shoes are a must.
  3. May 20, 2024 at 8:23 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Get some good AT tires. The rear bumper cover dragging and popping off is the weakest link on tougher trails. Front bumpe valance can have same problem as rear bumper popping off.
    Some sliders and skids if you want some protection against rocks on harder trails. An external compressor works fine for plenty of folks not wanting to spend on on board air.
    One thing about sliders. If you don't have them and take an unanticipated hit it can be very expensive body damage. My opinion buy then if your planning on going trails with some rocks.
    MeefZah and Wildfish[OP] like this.
  4. May 20, 2024 at 8:27 AM
    Cati
    Cati New Member
    Recovery gear, AT tires (AT4W 275’s), Sliders (SSO), undercarriage protection (Full RCI, Engine, transmission, transfer case, fuel tank (Cali), rear shocks, rear control arms), and lift (eibach). That’s what I have and probably spent around $4500 in total. For $2500, do the recovery gear, sliders, AT tires.
    Wildfish[OP] likes this.
  5. May 20, 2024 at 8:31 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Welcome and congrats on the new rig!
    The stock 4Runner is dang capable with just tires.
    Tires and sliders are probably a good place to start.
    If you start wheeling hard you'll discover small weaknesses here and there.
    I'd recommend finding those weak points and addressing them over time. As you run harder trails you'll have a good idea of what your rig "needs" for your specific use case.
    Everyone will have different opinions on this because informed opinions come from experience and everyone has different experiences ;)
    Go enjoy your rig in stock-ish configuration and you'll find out what you may or may not need for your use.
    Have fun on your trip!
  6. May 20, 2024 at 8:35 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I think people have a slight misconception about Moab. Yes there are some serious rock crawling trails that require special equipment, but for the most part, your stock 4R is going to be perfectly capable to access some awesome country. Sure, throw some tires on, and if you think air downs will do you good, get a compressor. Shit, when I was a kid, we did some crazy stuff in a stock 1986 Jeep Wagoneer. You're already miles ahead of that.
  7. May 20, 2024 at 8:35 AM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    I think you got a good plan already. $2500 should cover upgrading the stock tires, a compressor to air back up before hitting the pavement again, and lots of gas money.
    Btw, welcome to the forum
    Ironguy and Wildfish[OP] like this.
  8. May 20, 2024 at 8:35 AM
    Manhattan
    Manhattan New Member
    Tires and sliders.
  9. May 20, 2024 at 8:41 AM
    White castle sliders and tyre's
    MeefZah and Captain Spalding like this.
  10. May 20, 2024 at 8:46 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    And a 5 gallon bucket with toilet seat.
  11. May 20, 2024 at 9:08 AM
    Just install that gamer chair from idiocracy into your 4runner
    Garlic likes this.
  12. May 20, 2024 at 9:23 AM
    Wildfish
    Why?? I loved them on the Subaru but I'm open to others. Can you give me some reasons to stay away??
  13. May 20, 2024 at 9:25 AM
    Not sure why falke s are now bad?? Also would like some answers..
    Everywhere I go all I see is falkens tires
    Stoney Ranger and 2018 Limited like this.
  14. May 20, 2024 at 9:26 AM
    Wildfish
    This is EXACTLY the kind of advice I was hoping for. I really don't want to start changing the driving character if I don't have to. Plus I already shelled out a ton of money. Glad to know I can enjoy the trip without going into debt. For sure new tires, but otherwise I might stay stock and see how it goes
  15. May 20, 2024 at 9:33 AM
    Wildfish
    I see KO2s. Curious about the new BF model. But the Wildpeaks were great for me until they started to wear out. Then they became a little noisy.
  16. May 20, 2024 at 9:35 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Nah duelers can do well….
    get sliders. There will be drop offs on easy to medium trails(e.g. long canyon) that will make you feel not sufficient ground clearance. Having sliders will give you a peace of mind
    recovery kit
  17. May 20, 2024 at 9:38 AM
    Spare Parts
    Southern Maine
    22 LR ORP
  18. May 20, 2024 at 9:41 AM
    Yobruhitsme
    Denver
    Ineos Grenadier
    I have seen enough stock 4r off road videos to convince me then duelers will do fine for easy to medium trails.
    have done fine so far around the front range easy trails. Have only had mine since dec. so haven’t fully exercised the 4r yet
    the slick rock terrain in Moab are actually very “sticky” not “slick” at all.
    akakaiser likes this.
  19. May 20, 2024 at 9:41 AM
    All you need is tires matched to your operating environment.
  20. May 20, 2024 at 9:45 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    I am not familiar with Moab so I can not speak to that. But will say tires are a HUGE improvement.
  21. May 20, 2024 at 9:46 AM
    Wildfish
    Sadly, mine came with dunlop grandtrek
    Bagman likes this.
  22. May 20, 2024 at 9:50 AM
    2021venture
    Todd
    2021 Venture
    Consider losing the predator steps or other non slider options. These can be a liability catching and dragging depending what your rig came with.
    Seen a couple trail mangled examples
    akakaiser and Spare Parts like this.
  23. May 20, 2024 at 9:56 AM
    Yobruhitsme
    Denver
    Ineos Grenadier
    This dude has grantrek I believe. Tire was not the issue on poison spider(the trail in the video).. lack of fwd visibility and no armor likely resulted in hesitation
    https://youtu.be/oKB2FgNp4OQ?si=nwJ4nbKfC2iPnfz6
    stock duelers keeping up with bronco. Not Moab, but you get the idea
    https://youtu.be/yCd_pTPI7-8?si=iLTdArbx3qPam1P3
    my thesis is for many 4r owners, they over estimate their off roading tire needs..
    Slopemaster likes this.
  24. May 20, 2024 at 9:58 AM
    I have better than 30,000 miles on my Falkens, Fine tires. Tires and good sliders will work for most moderate offroading.
    Good Luck.
  25. May 20, 2024 at 10:05 AM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    Slick rock is slick when its wet, sticky when dry.
    Tires is all you need to get to the easier trails. Trails rated equal or harder than Fin's N Thing's you are going to want sliders and armor.
    I am not a fan of my Falkens, AT3W's in 275 in c load. Losing traction in snow and gravel when I shouldn't be, losing traction before traction control nanny's kick in even. Most overrated overhyped tire on the 4runner planet. That said they should be fine in Moab unless wet.
  26. May 20, 2024 at 10:30 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Same advice as others: tires.
    In order to do trails, you need traction. That starts with tires.
  27. May 20, 2024 at 10:40 AM
    Yobruhitsme
    Denver
    Ineos Grenadier
    Yep!
    this guy is a fearless driver.. probably the best demonstration of skill, at least on YouTube.
    OP: in this video, everything is doable on stock rubber… you gonna be doing more difficult trails? armor will give you confidence and better quality of life.
    https://youtu.be/_w2DmsCO1dg?si=k-Rtq-kQ54oPrPQ9
  28. May 20, 2024 at 10:44 AM
    TRDSD
    2019 TRD Off Road Premium
    Tires, sliders and a way to air up/down (like a Viair) will make for an enjoyable trip, as long as you stay off the advanced trails. Highly recommend sliders because it doesn't take much to drag and drop on your rocker panels - and it's among the most difficult to repair and expensive body work.
    Stoney Ranger and Acesandeights like this.
  29. May 20, 2024 at 11:28 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    To add to the tire discussion, for me my factory tires puncture easier when I’m driving the off road, logging roads, than my Goodyears
  30. May 20, 2024 at 12:57 PM
    Ok maybe I wasn't there bur it's like your eye guide told you to in the beginning of video to just gouge your oil pan on that giant rock LOL
    HuskerRunner likes this.
