Freedom offroad 2-5" Adjustable Strut lift
Discussion in 'General 4Runner Talk' started by Fman, Nov 19, 2019.
  1. Nov 19, 2019 at 6:11 PM
    Fman
    Fman [OP] New Member
    2004 4runner
    Adjustable lift, 285s
  2. Nov 19, 2019 at 6:31 PM
    Dark Knight
    Dark Knight Get off my lawn
    I bet that rides like shit. At that lift height you have zero down travel left.
    3.25”-5” lift is unobtainable without a drop bracket lift.
    Even with the silly diff drop your cv angles are likely still garbage.
    Point being:
    But, welcome to the site.
  3. Nov 19, 2019 at 7:46 PM
    Click on "thread tools"
    Should be in you original post somewhere. I'll check...
    Here...
    Welcome to the forum!
    Fman[QUOTED][OP] likes this.
  4. Nov 19, 2019 at 8:56 PM
    Fman
    2004 4runner
    Thanks for the welcome :) surprisingly the lift rides identically to the prior 1.5" spacer/OEM strut lift. This is just an option for people out there, really focusing on people interested in the Icon stage 1. As mentioned you can adjust it from 2-5". At 3" with diff drop kit our CV boot fins are not touching, good enough imo for what we will be using vehicle for.
  5. Nov 20, 2019 at 3:21 AM
    I can't imagine why this would be a problem anyway. Many people are running 3" lifts without dropping the differential, if I'm not mistaken.
    I plan on lifting the front 2-3" eventually, and I definitely will NOT be lowering the differential. The whole reason for lifting the front is to gain some ground clearance. If you drop the differential, you just lost any clearance you've gained.
  6. Nov 20, 2019 at 6:55 AM
    I like that it's an adjustable front strut kit. That's really cool!
    I don't like that the minimum lift height is 2.5". I would rather the adjustments went from 0-3" personally.
    I heard that Eibach will be coming out with something similar soon, for both the front and back. I think it will be more along the lines of 0-3" adjustment.
    Thanks for the review! Much appreciated :cheers:
