Frame rust
Discussion in '2nd Gen 4Runners (1990-1995)' started by Jesse4x42002, Jun 18, 2023.
  1. Jun 18, 2023 at 12:50 AM
    Jesse4x42002
    Jesse4x42002 [OP] New Member
    Jesse
    1994 4 runner 2.8
    None
    I’m thinking of buying this 4runner and I’m worried about the rust. Is this repairable and can it be done with just a wire wheel? Cheers guys!
  2. Jun 18, 2023 at 3:49 AM
    Welcome from Wisconsin! It looks like some of the major components are fixable, but maybe sand blasting would be better? The lower control arms are replaceable.
  3. Jul 13, 2023 at 7:51 AM
    kingroon
    kingroon New Member
    Matt
    London Town
    1994 3.0L V6 Toyota 4Runner
    Wire Wheel and then 2K Paint should be good on that Rear Axle, did as much to mine.. Can just as easily be done in situ..
    [​IMG] [​IMG] [​IMG]
    As for the Front Lowers, might as well replace those [as well as the Uppers..?] as @Toy4X4 suggests..
    I'd suggest a Panhard Bracket extension too, to accommodate the Suspension Lift and keep the Bar level..
  4. Jul 13, 2023 at 8:25 AM
    Ironguy New Member
    Welcome from Arizona. Elbow grease, power tools, wire brush, paint. Doesn't look bad at all.
    kingroon likes this.
  5. Jul 14, 2023 at 1:50 AM
    Looks good so far. Iwent through a restoration like this once, it's a lot of work, sometimes the hardest part is getting going on the project! Keep us posted... thanx.
    kingroon[QUOTED] likes this.
  6. Jul 14, 2023 at 2:06 AM
    kingroon
    kingroon New Member
    Matt
    London Town
  7. Jul 14, 2023 at 2:10 AM
  8. Jul 14, 2023 at 5:53 AM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    $$$$ You goin' to need some of these for that restoration!:D $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
  9. Jul 14, 2023 at 7:02 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    mrmike7189 likes this.
  10. Jul 14, 2023 at 7:11 AM
    Honestly that doesn't look bad too me, going by northeast standards.
    I would want to see pics of the most common failure points before making final judgement though.
    At the least, you're in for a lot of sanding/wire wheeling with that. Depending on how far you want to go, having it dry ice blasted might be worth it.
