Former Two FJ then two Taco family. Wife now has a runner
Discussion in 'New Member Introductions' started by BC Hunter, Jan 27, 2024.
  1. Jan 27, 2024 at 9:30 AM
    BC Hunter
    BC Hunter [OP] New Member
    Paul and Jane
    Kootenays BC Canada
    2024 TRD Pro-Terra
    Stock so far…..
    Used to have a pair of FJ Cruisers, but we lost them in an acid spill incident in our city in 2018.
    Wife has a very nice DCSB with a manual transmission; upgrades to wheels and tires, tonneau, and a skid plate. She does need the 4x4 to get to and from our remote cabin.
    She likes the Runner, but not some of the missing features she has on the Taco. Hoping to see what the 6th gen offers.
    kolter45 and Han4Run like this.
  2. Jan 27, 2024 at 9:45 AM
    BC Hunter[OP] likes this.
  3. Jan 27, 2024 at 10:12 AM
    Welcome.
  4. Jan 27, 2024 at 10:14 AM
    Ironguy New Member
  5. Jan 27, 2024 at 10:20 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Welcome here! Heck of a place to be for knowledge
    There's a ton of threads here talking about how much folks liked switching from Tacos to 4R's. The Search feature here works great for research reading. But it's give and take when considering switching, a pick up vs an SUV.
    That's wild about an acid spill.
    Then I looked closer at your city and was pleasantly surprised, a fellow BRITISH COLUMBIAN! Very few of us :hattip:
  6. Jan 27, 2024 at 10:33 AM
    kakwvu
    kakwvu New Member
    Almost Heaven, WV
    ‘21 Lunar Rock TRD Pro
    I used to have a third gen Tacoma and now a 21 T4R Pro. Compared to my 2016, I’m only missing BSM, which broke in it anyways :(
    My ew has a Lincoln Corsair with all the tech you could ask for (lane centering cruise control) and loves driving the 4R.
    BC Hunter[QUOTED][OP] likes this.
  7. Jan 27, 2024 at 11:15 AM
    DesertSurfer
    DesertSurfer New Member
    One of each flavor is not unheard of. Welcome to the forum!
    2Toys, BC Hunter[OP] and Han4Run like this.
  8. Jan 27, 2024 at 6:19 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
  9. Jan 28, 2024 at 5:04 AM
    welcome
  10. Jan 28, 2024 at 5:30 AM
    Wildboar52
    Wildboar52 Slightly off
    Jack
    Fuquay Varina, NC
    2024 TRD Off Road Premium silver
    None. Yet.
    As an ex owner of several Tacomas, as well as a Jeep Gladiator, I have to say that I miss the ability to load lumber on the truck with little difficulty, BUT, I now can easily load up the kids and the dawgs and we can get somewhere with comfort and what feels like added safety. So I’m not looking back. And, I feel like the 5th gen is gonna be very desirable when the 4 banger becomes the standard engine. I’m not a mechanic by any stretch, just old school. . Welcome from North Carolina!!!!!!
  11. Jan 28, 2024 at 6:19 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Before I made the “command decision” (lol) to purchase my pre-owned / certified 2022 4RUNNER SR5 Premium 4WD this past November, I also test drove a couple of Tacomas at my Toyota dealer. One Tacoma was a 2021 and the other a 2022.
    I was coming out of my long time friend, my 2006 TUNDRA TRD SR5 4WD Double Cab, that I had purchased new for myself.
    For grins and giggles, I also test drove a big 2020 Tundra while I was at the dealer. Wifey thought the Tundra was just too ridiculously big and bulky. She was also going to be driving my next choice of vehicle from time to time, so I was trying to honor her inputs. She nixxed the huge bulky Tundra.
    But, I digress- back to the Tacomas- Those two Tacomas, being so much newer than my “antique” ‘06 Tundra just didn’t seem to “float my boat” like I thought they should have.
    I didn’t like the ergonomics of the driver’s seat, the back seat felt cramped for leg room, and I didn’t particularly like the mannerisms of the engine or transmission.
    But when we both drove that 4RUNNER, we thought hey this is pretty nice. My wife was enthused with it, and she was surprised and happy with the visibility to the rear and through the side windows towards the rear.
    She did offer one criticism or warning however- She told me that I wouldn’t be able to haul dirty stuff or throw crap in the back end of the 4RUNNER like I could with my Tundra. I agreed that I wouldn’t want do that. She said you are going to miss that open bed on your Tundra.
    I countered with yeah I guess I’ll have to buy a utility trailer to pull behind the 4RUNNER. She said no dice to a trailer, as we have no place to store one inside. She said we are not going to pay extra for registration for a trailer, then leave it set outdoors to rot in the sun and weather, not to mention the threat of it being stolen.
    She said for the 3 or 4 times a year that we may actually need a trailer, we can just rent one from like Home Depot or U-Haul.
    And so with that in mind, between the choice of a gargantuan too big Tundra, and not being thrilled with the Tacoma test drive experience, we settled on the 4RUNNER.
    We haven’t regretted it for even one second. We love this 4RUNNER.
    Incidentally, wifey’s car is a 2021 RAV4 XLE Hybrid full time AWD. NOT the plug in hybrid. I don’t see the sense of having to plug one in. That RAV4 Hybrid is great. We love it. We are Toyota folk. lol.
  12. Jan 28, 2024 at 9:56 AM
    4RUNN3RUT4H
    4RUNN3RUT4H New Member
    Chris
    2022 4Runner Limited Nautical Metallic Blue, Redwood Interior
    We just bought a 2022 4R Limited, too, and we also love it!
    Congrats on the 4R!
  13. Mar 23, 2024 at 2:25 PM
    BC Hunter
    Paul and Jane
    Kootenays BC Canada
    2024 TRD Pro-Terra
    Stock so far…..
    Update: we settled on a deal for a new 2024 4Runner TRD Pro for my wife, in exchange for her 2019 Tacoma DCSB 6MT Sport Premium…..and a bunch of Canadian dollars.
    The runner is supposed to arrive in a few weeks and she is very excited.
    We put the summer tires and wheels (16”) on the Taco, and kept the winter tires on 17” rims to use on the Runner next November.
  14. Mar 23, 2024 at 2:27 PM
    Dabigono
    2020 4Runner
    Wow ^^^^
  15. Mar 23, 2024 at 3:31 PM
    Trouble24
    Trouble24 New Member
    Steph
    Leavenworth, WA
    Ceramic Tint Prinsu Pro Roof Rack 3” Westcott lift ARB Awning
    Welcome from WA!!
  16. Mar 23, 2024 at 6:11 PM
    Nutmegtheref
    Nutmegtheref ****
    2021 TRD Pro
    Let’s hear about the acid spill incident! That sounds wild.
    2Toys, Trail Runnah and WilVis like this.
  17. Mar 24, 2024 at 7:37 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Welcome from Denver! :cheers:
  18. Mar 24, 2024 at 10:32 PM
    steelevo
    Utah
    Welcome. The Terracocca color is starting to grow on me.
  19. Mar 25, 2024 at 4:23 AM
    Was thinking the same thing. Come on, spill it!
    2Toys likes this.
  20. Apr 9, 2024 at 9:30 PM
    seakuv
    seakuv New Member
    Dave
    Palmer, Alaska
    2024 TRD Offroad Premium
    Falken Wildpeak A/T3W, All interior lights LED, Twiststep for the doggo,
  21. Apr 23, 2024 at 7:35 PM
    BC Hunter
    Paul and Jane
    Kootenays BC Canada
    2024 TRD Pro-Terra
    Stock so far…..
    Trouble24 likes this.
  22. Apr 27, 2024 at 3:32 PM
    BC Hunter
    Paul and Jane
    Kootenays BC Canada
    2024 TRD Pro-Terra
    Stock so far…..
    Photo of the new Toy. Wife is very pleased.
    Dabigono, 2Toys, kakwvu and 1 other person like this.
  23. Apr 27, 2024 at 5:30 PM
    kakwvu
    kakwvu New Member
    Almost Heaven, WV
    I really like Terra. I found a used 2021 Pro locally with low miles so I went that route, but I think this color looks great too.
  24. Apr 27, 2024 at 5:51 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Perfect pair!!
  25. Apr 27, 2024 at 5:52 PM
    2Toys
    Gordon
    2019 4Runner TRDORP
    Nice play on words!! :D
