For those with ladders….and those that think they’re ridiculous
Discussion in '5th Gen 4Runners (2010-2024)' started by nimby, Jan 11, 2024.
  1. Jan 11, 2024 at 7:45 AM
    nimby [OP] in the drink
    PVT Pablo likes this.
  2. Jan 11, 2024 at 8:02 AM
    nimby[QUOTED][OP] likes this.
  3. Jan 11, 2024 at 11:34 AM
    wax poetic
    wax poetic Raking like a mofo
    21 Super White TRD OR
    My wife and I go to Goldwater and sit and play games and have a beer every so often as it's just 5 min away. If they have any when I'm there I'm gonna pick some up haha
    nimby[OP] likes this.
  4. Jan 11, 2024 at 10:17 PM
    wax poetic
    Well I got me a Wittle Wadder hahaha Eventually I'll get to the point where I need one, but for now these 4 will do
    nimby[OP], Spare Parts and djwantke like this.
  5. Jan 11, 2024 at 11:28 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Ok I'm dumb, how do I get this beer in Washington?
  6. Jan 11, 2024 at 11:49 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I just searched for sales of this myself haha can't find a damn thing, except this very clever funny description, "Climb up your widdle wadder to the top of your woof and enjoy this new Wit Bier brewed with Orange Peel & Coriander!
    In the wain, or in the wiver, this beer will take you to where you wanna be!"
  7. Jan 12, 2024 at 12:11 AM
    wax poetic
    It's Goldwater Brewing out of Scottsdale AZ. You'd have to find someone to ship you some ;)
    nimby[OP] and Spare Parts like this.
  8. Jan 12, 2024 at 3:46 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    My son is going to get some for me. His work isn't too far from there. They're selling T-shirts too. Online orders only for those.
    nimby[OP] and wax poetic like this.
  9. Jan 12, 2024 at 6:10 AM
    wax poetic
    Some stickers too... for pwe-order :D
    Guppy1301[QUOTED] and nimby[OP] like this.
  10. Jan 12, 2024 at 10:11 AM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    I can’t tell, is that a 4th or 5th gen?
    :rolleyes:
  11. Jan 12, 2024 at 12:04 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    you forgot to mention the TRD PWO :D
  12. Jan 12, 2024 at 12:06 PM
    wax poetic
    :D:D:D
  13. Jan 12, 2024 at 12:15 PM
    The what? Lol
    wax poetic likes this.
  14. Jan 12, 2024 at 12:24 PM
    semprenissart
    semprenissart Mèfi
  15. Jan 12, 2024 at 3:24 PM
    Guppy1301
    Silver 2019 TRD ORP
    What woof wack is that? Westcott?
  16. Jan 12, 2024 at 3:31 PM
    I bet someone that works at the brewery has a 4Runner with a "widdle wadder" and they are the inspiration behind this whole thing.
    You know they're taking a beating from all the other employees at the moment. :rofl:
  17. Jan 12, 2024 at 3:32 PM
    wax poetic
    Hahaha, I wish I knew the backstory but it's probably at the main brewery not the little secondary one near me
  18. Jan 12, 2024 at 3:37 PM
    I'm surprised it's not a nasty IPA.
    Doglover2003 and Spare Parts like this.
  19. Jan 12, 2024 at 11:43 PM
    Ha! This thread gets better....
    If it was a Westcott ladder, it would look properly. As shown, it looks like a gobbi or prinsu. We are going to have to taste this beer one day.
    Guppy1301[QUOTED] likes this.
  20. Jan 13, 2024 at 1:51 PM
    wax poetic
    I'm 2 in so far :)
  21. Jan 13, 2024 at 2:15 PM
    @whippersnapper02
    @Spare Parts
    Hey hey hey take it easy on the IPA's lol
    At least I enjoy Canadian IPA's and not hipster Portland
  22. Jan 13, 2024 at 2:23 PM
    wax poetic
    It's alright my man, I love some VT and some AZ IPA's so ... haha
  23. Jan 13, 2024 at 3:32 PM
    Idk about Canadian IPAs but the ones here taste like Pine Sol. The doubles taste like a mix of Pine Sol and Fabuloso.
  24. Jan 13, 2024 at 3:53 PM
    Yeah no they kinda all are strong af :p
