Fog Lights
Discussion in '3rd Gen 4Runners (1996-2002)' started by gretzky2857, Dec 4, 2020.
  1. Dec 4, 2020 at 7:43 AM
    gretzky2857
    gretzky2857 [OP] New Member
    2002 4Runner
    I put new fog lights in my 2002 4Runner a couple years ago. For whatever reason, they're BOTH not working and I checked and bulbs are still good. Any suggestions is appreciated!
  2. Dec 4, 2020 at 10:17 AM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    fuse blown ?
    negusm likes this.
  3. Dec 4, 2020 at 11:06 AM
    I had a weird issue on my daughter's Mazda 3 with Fogs. Bulbs were good, dash switch would actuate the relay so you could hear it click. Power seemed to be there in the fuse panel. Still not working. Pulled the relay and fuses, swapped them around with the headlight relay which I think was the same and they are all working again. Swapped everything back, still working. No idea what the real problem was. Maybe a stuck or faulty relay?
    I would check the fuse panel and test for voltage, etc. Pull the fuses and relay and reseat.
  4. Dec 4, 2020 at 11:32 AM
    Did they work a couple years ago and just recently quit working?
  5. Dec 4, 2020 at 11:43 AM
    Starr
    Jonathan
    SouthEast Maui
    Check the ground or neg connection.
    negusm likes this.
  6. Dec 5, 2020 at 7:02 AM
    gretzky2857
    2002 4Runner
    Thanks for the info guys. So far I have checked the fuse and it was good but that’s all I’ve done. They both worked great for over a year then both quit at the same time. I’ll keep on looking into it.
