Fog Light Replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by bluecowisasian, May 7, 2024.
  1. May 7, 2024 at 12:54 PM
    bluecowisasian
    bluecowisasian [OP] New Member
    Hi all,
    just got SS3 Max for my 4R, pardon my ignorant but is it possible to remove and replace OEM fog light and install SS3 without removing the wheelwell liners ? all tutorials in seen YT requires either unclip it and/or drop the whole front bumper. Thanks
    T in Texas and raimieb like this.
  2. May 7, 2024 at 1:25 PM
    Try removing the top plastic cover just behind the grille. The one with 13 push clips. You might be able to reach down and do it. Loosening the edge of the fender liner is no big deal, however. It's like four bolts. You can then push it back and reach in. No need to remove it totally.
    raimieb likes this.
  3. May 7, 2024 at 1:38 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
  4. May 7, 2024 at 1:43 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I was able to replace mine from underneath. I think the drivers side i needed to partly remove the wheel well cover.
  5. May 7, 2024 at 1:53 PM
    bluecowisasian
    i see that the passenger side has a cover for the fog... im assuming i have to partial unbolt the liner to pull it off huh ...
  6. May 7, 2024 at 1:55 PM
    bluecowisasian
    also follow up question, my Pro is stock height so is it necessary to aim/readjust the aftermarket fog after install or is it one of those thing just install and good to go ?
  7. May 7, 2024 at 2:54 PM
    My advice would be to find a wall somewhere where you can shine your oem fogs on at a specific distance, and make a reference mark. Then you can park in the same spot after installing the SS3 lights, turn on the fogs and compare. That should give you what you need. Maybe overly simplistic, but should get you in the ballpark.
  8. May 7, 2024 at 3:01 PM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    I bent mine back for the install.
    Have fun doing a combination of yoga and kama sutra to get that fog light shroud off on the passenger side.
    2016SR5P and bluecowisasian[OP] like this.
  9. May 7, 2024 at 9:07 PM
    4runningMan
    4runningMan New Member
    New Mexico
    I did the drivers side easily from underneath. For passenger side, unbolt the fender liner. Trust me. It will save you a lot of frustration.
    For aiming. Don’t push the DD fogs all the way forward when installing. Leave about a 1/8” gap top and bottom. That will allow you to push in on the bottom edge of the light from the outside in order to aim in downward, resulting in about ~1/4” gap at bottom and no gap at the top. That little amount of “play” will give you some adjustability for aiming. If you get flashed a lot, just point it down a little more.
    But marking OEM’s on a wall at a set distance is a good way to get a reference point.
  10. May 7, 2024 at 10:19 PM
    scottiezilla
    scottiezilla New Member
    100% aim
    Especially if you got the MAX in regular WHITE light
    They differ in power/brightness/ lumens/something? than if you opted for the amber
    My AMBER PROS are extremely bright, albeit they’re in a hefty bumper with suspension but still MAX is gonna be briiiiiiiiiiiiiight
    side note, bumper/lift or not, no need to tighten hardcore, which will allow you to adjust the aim easier if need be
    However that’s with my my STANDARD bracket, not sure how it goes if you got the flush mount or oem replacement thingamajig
  11. May 8, 2024 at 5:18 AM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Diode Dynamics lists the outputs on their site. 31% light loss from 6000k to 3000k. Independent testing shows it’s only 19% though
  12. May 8, 2024 at 8:53 PM
    scottiezilla
    yeeeeah I knew I read or watched something bout it when I got mine last black friday
    Just didn’t know the specs offhand
    regardless, the aiming of the lights really is considerate n performance/function based
    so @bluecowisasian id just do what everyone is saying n find a wall or what not, 25feetish away
    Aim accordingly so fog lights work as expected
    this is 100% why I didn’t get flush mounts for my bumper…the hefty isn’t angled down at all, would have been easier/cleaner install but would have been pissing everyone off while driving
  13. May 9, 2024 at 3:15 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    Did you get the amber backlight?
    What do you think of the lights?
  14. Sep 8, 2024 at 7:00 PM
    4runningMan
    New Mexico
    Does anyone have a photo of the splash guard that sits over the passenger side fog light? I broke the tabs on mine several years ago while ripping it out in frustration lol. We don't want to break the tabs on my my friend's install next week.
    Thought if I have a pic of the tabs we could more easily finesse it out.
  15. Sep 9, 2024 at 10:02 AM
    Bend_4R
    Bend_4R New Member
    Use a flathead screwdriver inserted along the tabs and they will pop out. It is awkward and not particularly easy, but wont take more than a couple of minutes to figure out.
  16. Sep 9, 2024 at 10:06 AM
    Bend_4R
    Bend_4R New Member
    I found the SS3 Max didn't have what I would consider a usable adjustment range, and angled the lights as far down as they would go with a 2” lift on an Off Road. The brightness and beam pattern work perfectly angled all the way down, and I have never had anyone flash their lights at me.
