Fog light question
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Nov 19, 2022.
  1. Nov 19, 2022 at 4:44 PM
    morfdq [OP] New Member
    Hi
    Quick question. With fog lights are you supposed to keep your headlights on when driving it rain or snow. I’m replacing my OEM fog lights with Diode Dynamic yellow fog lights. I didn’t know if in rain snow you kept the headlights on. Thank you
  2. Nov 19, 2022 at 5:24 PM
    Charlievee
    Charlievee New Member
    Don't believe the fogs come on unless the headlights do. One of the many nanny state things on my delete list.
    Stoney Ranger and Thatbassguy like this.
  3. Nov 20, 2022 at 3:22 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I have the DD SS3 Pro’s on my 2021 OR and if you wire them into the factory fog light harness with the DD supplied harness, they will only work when low beams are on just like factory fogs. I have mine wired this way. Many states require you to have headlights on when it’s raining so it makes sense for them to work this way from the factory.
    if you want them to work independent of the headlights, you certainly could wire them to run off a separate switch.
    Cheers,
    Bob
  4. Nov 20, 2022 at 3:40 AM
    Like mentioned, fog lights are powered off the headlights low beams. You can run a separate wire to power them independently. But to answer the question, its not a good safety idea to run just fogs in serious conditions.
    Fog lights are there to fill light gaps closer to the road, not for main vision.
  5. Nov 20, 2022 at 6:45 AM
    Metalsaber
    Metalsaber New Member
    basically this
    Steely123[QUOTED] likes this.
  6. Nov 20, 2022 at 9:32 AM
    Charlievee
  7. Nov 20, 2022 at 10:13 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    I'll second (or third) this but add one more detail. The thing you really want to avoid is running your fogs and your high beams at the same time. This isn't much of a problem if your truck is stock because your fogs (if activated) will shut off when you switch from low to high beams anyway. The rationale is that your fogs are for short distance / peripheral vision and your high beams are for long distance vision. If you were to re-wire things so you could run both at the same time, your pupils would react to the intense foreground light and constrict, thus limiting your distance vision - which would be bad.
    Trust me, if you swapped your OEM fogs for DD SS3's - no matter which model - between them and your low beams, you'll be just fine. Just make sure to aim them properly.
