Fog light issues
Discussion in '5th Gen 4Runners (2010-2024)' started by BigFootPatrol, Mar 19, 2023.
  1. Mar 19, 2023 at 3:06 PM
    BigFootPatrol
    BigFootPatrol [OP] New Member
    Ron
    2017 4runner SR5 Black
    So both my factory fog lights stopped working on my 2017 SR5. The bulbs are good, the fuse is good. I can't find the relay if there is one. In the hood fuse/Relay box cover there is nothing that specifically says "Fog lights" except the multifunction Alt fuse, which seems to be working. Does anyone know where the fog light relay is or where do I go from here?
  2. Mar 19, 2023 at 8:14 PM
    Do you have a multimeter to check for voltage at the light?
  3. Mar 20, 2023 at 8:49 AM
    BigFootPatrol
    Ron
    Yes, I'll start there tonight.
  4. Mar 20, 2023 at 6:34 PM
    BigFootPatrol
    Ron
    Much to my surprise I did get a voltage reading when I tested at the light socket. Correct me if I'm wrong, but that can only mean the light itself is bad, even though it looks fine? I had my wife turn the switch on and off and the meter reacted accordingly.
  5. Mar 20, 2023 at 8:53 PM
    Agent_Outside
    Built 2011 T4R Limited
    Power is only half of the circuit. Did it have ground?
  6. Mar 21, 2023 at 10:22 AM
    BigFootPatrol
    Ron
    How do I check that?
  7. Jul 13, 2024 at 9:09 AM
    Fast1911
    Fast1911 New Member
    MMA
    2016 4Runner SR5
    Upgrade rotors and shoes, leather, working on Bilstein struts&shocks
    Did you ever get an answer on this or figure it out? My 2016 4Runner same, new bulbs, replaced fuse even though it looked fine, still nothing.
  8. Jul 13, 2024 at 10:12 AM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    you could use a continuity tester,
    remove the wiring from back of fog light,
    identify the power wire, attach the clip on the circuit tester to the power side of the wiring harness that attaches to fog light,
    use the probe to touch the ground side of the fog light wiring harness,
    turn on the power...
    if it lights up, you have ground to the bulb
    https://www.amazon.com/gp/product/B094PZMBXY/
