Fog light bulb replacement - the quicker way
Discussion in '5th Gen 4Runners (2010-2024)' started by Emmantik, Dec 5, 2022.
  1. Dec 5, 2022 at 10:51 AM
    Emmantik
    Emmantik [OP] New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    There is an easier way to replace your fog light bulbs other than having to go through the fender liner. Both fog lights can be reached by reaching from the bottom underneath the front. Most posts/videos I've seen showed that you need to remove the fender liner. Finally replaced the driver side factory OEM bulb after owning for 7years since new. I saw this vid and realized you can do the same on the driver side. Cheers!
    4Runner 2018 5th Gen fog light LED mod - the right way - YouTube
    Slopemaster likes this.
  2. Dec 5, 2022 at 11:12 AM
  3. Dec 5, 2022 at 12:31 PM
    S8ULATR
    S8ULATR New Member
    CA
    2 Germans & a Beast
    Thanks! In your opinion, is there enough room to actually replace the housings themselves (ie when upgrading to SS3's or similar) ? Or, is it just big enough to pop the bulb out and replace?
    Overland WT likes this.
