Flickering Brake Light/Loss of Throttle
Discussion in '4th Gen 4Runners (2003-2009)' started by Ommoorehead, Mar 23, 2024.
  1. Mar 23, 2024 at 2:23 PM
    Ommoorehead
    Ommoorehead [OP] New Member
    Matthew
    2004 4Runner 4X4
    Hello,
    I just bought my daughter this 2004 4X4 4Runner. Everything seems to be running strong. While driving on the freeway after a while, the break light will flicker and I lose power. If I let off the throttle and then press it again it will go. It will happen for a few miles then go away. Side note, the VSC lights are on as well, not sure if that is playing a factor. Any help would be greatly appreciated.
    Hopping I didn’t get screwed on this deal.
    Thanks
  2. Mar 23, 2024 at 4:33 PM
    3JOH22A Toyota Gigolo
    ^Load test your battery and make sure the terminal clamps are tight.
    Do a visual/tactile check on the brake pedal switch for looseness and wire connector corrosion.
    RumHamRunner73 likes this.
  3. Mar 23, 2024 at 8:42 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    My Tacoma did this literally two days ago. Was driving to work, ABS and VSC lights came on and the parking brake light flickered, and my speedometer needle was going haywire. Got to work, scanned it for codes, nothing came up. After work drove it home and everything was back to normal. I’m wondering if my battery is going bad.
    side note I’ve never had a single issue with my Tacoma at 93k miles (2014 v6 4x4 auto) until this
    Ommoorehead[OP] likes this.
  4. Mar 23, 2024 at 8:50 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Not mentioned but very important is to clean and check all grounds connections, a bad ground can cause weird things to happen.
  5. Mar 23, 2024 at 9:04 PM
    Ommoorehead
    Matthew
    2004 4Runner 4X4
    Definitely going to go through the wiring tomorrow. Drove it about 100 miles today, halfway there it started and half way back it did it again. When it happens, I have to let off the gas pedal and then it goes. Will happen for a few minutes and then goes away. Thinking there is a bad ground somewhere. Previous own has done a lot of MOD work with lights and stuff.
  6. Mar 24, 2024 at 5:19 PM
    Ommoorehead
    Matthew
    2004 4Runner 4X4
    Got the VCS lights off, really cool video on YouTube using some paper clips in the OB plug and cycling the key that worked. Checked the connections at the battery. Still have the emergency brake light flicker and loses power simultaneously.
  7. Mar 25, 2024 at 6:57 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 263K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    You just bought the truck, what do you know about the battery? If you’re new to 4th Gens, it’s good to know that a weak battery can cause numerous oddball symptoms, for example random uncommanded rear wiper activation. Unless someone with a V8 has specific knowledge of this issue, I would start with the battery and charging system.
