FIXED: 2000 SR5 4x4 won't crank, ideas?
Discussion in '3rd Gen 4Runners (1996-2002)' started by T in Texas, Jun 28, 2024.
  1. Jun 28, 2024 at 3:49 PM
    T in Texas
    T in Texas [OP] New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    My 2000 4runner has ~232K on it, been running and starting fine
    Toyota battery is almost 3 years old, so was already ready to replace it...
    I was at the Toyota dealership, picking up some parts I intended to use this weekend...
    I came out and it would not crank...
    no slow cranking, no click, no nothing...
    horn honks, windows work fine...I put a boost box on it, and same thing
    checked the battery, and all connections tight and no corrosion
    I wondered if the alarm starter cutoff was on, so I cycled the alarm and even tried the remote start...same thing, would not even click
    lucky I was in front of the dealer when it happened, and they gave me a 2024 SR5 4runner as a loaner
    any ideas? I didn't whack the starter, figured if it was bad...I'd rather find out now than later
  2. Jun 28, 2024 at 4:22 PM
    Acesandeights
    Acesandeights #34
    So Oregon
    2024 ORP
    Whack it.
  3. Jun 30, 2024 at 4:17 PM
    T in Texas
    FEMA Region 6
    any other suggestions?
  4. Jul 1, 2024 at 8:55 PM
    Sounds like a bad starter relay? If no click, I doubt it's the starter.
    T in Texas[OP] likes this.
  5. Jul 1, 2024 at 8:57 PM
    Its the alarm. If it has remote start then its an aftermarket piece of crap. Remove main fuse to alarm. See if that helps?
    negusm and T in Texas[OP] like this.
  6. Jul 1, 2024 at 9:51 PM
    T in Texas
    FEMA Region 6
    I have not talked to the dealer yet, but their text system sent me a message...
    said tech could not duplicate problem, and battery needed to be replaced...
    I don't think this is the only problem because it acted the same way with my battery booster on it...
    I'm the 2nd owner, bought the truck in August 2004 and had the Clifford Intelliguard 900 alarm installed in December 2004
    alarm has never given me any problems, and I have not replaced the starter yet in 20 years and 232K miles, so its gotta be tired too
    when the dealer calls me, gonna talk about replacing the starter and ask about the alarm too
    Its a less than 3 year old toyota battery, so should be some warranty on it
  7. Jul 1, 2024 at 10:03 PM
    You dropped off a broke down 2000 4R at the dealership? Hope you got a new credit card?
  8. Jul 2, 2024 at 4:17 AM
    Starters never go bad on these. I really doubt it's the problem.
    Dealer should be able to diagnose with a simple multimeter. The starting system is not complicated.
  9. Jul 2, 2024 at 8:25 AM
    T in Texas
    FEMA Region 6
    I was at the dealer picking up $9 worth of screws and interior molding tabs, when I came out and it would not start...was just by chance I was at the dealer when it happened
    I've had the same Toyota dealership tech working on my car for years, so I trust them more than others...but my tech is on July 4th vacay, so got some random guy
    I don't have a new credit card, but feel like I just got a big raise...yesterday I separated from my GF of 15 years, and now the 2024 Camry I bought for her to drive goes back into my stable
    thanks for the info on the starter @negusm
    I will let you guys know what they dealer says and how much I get bent over...so y'all can laugh at me
  10. Jul 3, 2024 at 2:29 PM
    T in Texas
    FEMA Region 6
    well update from the dealer...
    they said it was only the battery, no need for starter or anything else...
    Im still skeptical, all windows and even horn worked...and not even a starter click
    $280 total for:
    -oil change
    -state inspection
    -diagnose and replace toyota battery...last toyota battery was done October 21, so I got a pro rated warranty discount
    they also gave me a 2024 4Runner as a loaner will fixing my 2000
  11. Jul 3, 2024 at 2:52 PM
    Starter draws 109374973493x more current that lights horns/etc.
  12. Jul 6, 2024 at 8:00 AM
    Also, if this happens again, suspect your battery cables. Had a similar issue and had to replace about 8" of negative battery cable. Also, wore out a TOYOTA battery in 11 months. Got a new battery for free and then I fixed the cable and that battery has been going strong for years now.
    Battery cables will corrode from inside out and you won't know it. And they are murder on batteries.
    T in Texas[OP] and 2Toys like this.
  13. Jul 6, 2024 at 9:30 PM
    T in Texas
    FEMA Region 6
    Thanks for the tip on the battery cables,
    I already learned that lesson with my positive cable and now stay on top of battery maintenance
    no issues with starting since getting my battery replaced
