Fitting 34 inch tires with a 3 inch lift in front and 2.5 in rear
Discussion in '5th Gen 4Runners (2010-2024)' started by juliancolombo, Nov 7, 2020.
  1. Nov 7, 2020 at 2:21 PM
    juliancolombo
    juliancolombo [OP] New Member
    Julian
    2019 trd pro 4 runner
    I am debating on what would be the best tires to put on my 2019 trd pro. I have a 3 inch lift in the front and a 2.5 in rear. I am debating between 285/75/17 or 295/70/17. Besides a body mount chop and removing the mud flaps is there any other trimming that will be required to prevent rubbing? Has anyone done this and can share some photos!
  2. Nov 7, 2020 at 2:37 PM
    Mtbpsych
    Mtbpsych New Member
    Aside from what you mentioned, UCA’s, hammer pinch weld, trim front bumper.
    I’m debating on switching to 285/75/17 for my next set as well though.
  3. Jan 17, 2021 at 2:03 AM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    So I was curious about this same modification. I wanted to run a bigger 33 inch tire (practically 34). However there were some concerns I had as well.
    My concerns are mainly focused in wear and tear of other components on the vehicle. Let’s say I get everything to fit just fine. Has there been anyone who has experienced damage to other components because of these things? The things I am thinking about are the following:
    Brake damage?
    Broken cv axels from the added weight?
    Stress on the engine, transmission, transfer case, etc that results in these components failing prematurely?
    Power steering failures?
    Etc.
    I watched a video of a guy who put on 35 inch tires on his 4Runner and it looked nice but then he was saying he had gone through 3 power steering pumps, had to custom install a little radiator type device to keep his power steering from failing and now he replaces the power steering fluid 3-4x annually.
    I hope someone with an engineering/mechanical background or someone with knowledge in this area (pretty much anyone besides me ;)) is able to chime in. Also anyone who has gone this route. Can you show pics of your 4Runner and your experiences.
  4. Jan 18, 2021 at 9:46 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    I'm concerned about these same things with my 275 Wildpeaks. As I'm new to modding trucks, I really have no idea how "over-built" the 4Runner is and if it can even handle the heavier tires at all. I'm not even thinking as much about the main stuff like engine/transmission (I'm sure they're fine), but more along the lines of bushings, ball-joints, etc.
    I think the stock tires are like 41 lbs? I didn't notice much with my 47 lb tires, but my current 58 lb tires worry me. I can't imagine going even heavier.. but maybe the truck can take it?
  5. Jan 18, 2021 at 9:59 AM
    Pay to play. But its worth it if you ask me.
    captrussia253 and Mtbpsych like this.
  6. Jan 18, 2021 at 10:15 AM
    GrantA
    North Carolina
    I looked up the items that would possibly need to be replaced over time and they are not expensive things. Just more maintenance kind of stuff. I would be willing to spend a few hundred bucks a year on maintenance and replacing those parts if it meant enjoying the routes less traveled.
    koukimonster likes this.
  7. Jul 28, 2023 at 8:15 AM
    ForrestTh4R
    ForrestTh4R New Member
    Caleb
    2022 ORP (currently stock)
    @Mtbpsych What wheel offset is this?
  8. Jul 28, 2023 at 11:30 AM
    jvilla1971
    jvilla1971 New Member
    I am currently running 295/70/17 MT. I have 3 inches in the front and back. I replaced my UCA to SPC (I believe they are adjusted to 3 degrees of caster). I did a BMC, removed mud flaps, and minor trimming of some plastic in the inside front wheel well. I don't have any rubbing and yes I do take it on challenging trails. I have had tires off the ground many of times. My wheels are a 0 offset.
  9. Jul 28, 2023 at 11:57 AM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Im going from 285 70 R17 to 285 75 R17 today and I'll let you know about the rub. I have a BMC and a 3/2" lift.
    djwantke likes this.
  10. Jul 28, 2023 at 1:34 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Nice man! Finally I can gauge how 285/75's will perform with a setup virtually identical to mine. By proxy through you sir, hahah
    Thank you
    :burnrubber:
    [3/2 lift, 285/70's, 0 offset 9"w wheels, SPC's, 'stage 3' bumper clearance cut including fender liner, BMC, pinch weld chop and weld, valance cap removed, wheel well hammered/liner chopped]
  11. Jul 29, 2023 at 12:27 PM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    @djwantke Ok got the 285 75 R17s installed and I have zero rub at full lock. The only fender liner trim I have done was what ever Toyota does at port. The BMC has lots of space as you'll see in the photos. Obviously everything will be dependent on offset and width assuming you wanted to go with a 295. IMHO opinion this might be the perfect tire size for lifted 4Runners!IMG_3442.jpgIMG_3441.jpgIMG_3444.jpg
    djwantke and SlvrSlug like this.
  12. Jul 29, 2023 at 2:55 PM
    Looks great.
  13. Jul 29, 2023 at 2:58 PM
    Aw yeah gorgeous my friend!
  14. Aug 13, 2023 at 8:44 PM
    Mtbpsych
    Mtbpsych New Member
    17x9, -38mm.
  15. Nov 14, 2023 at 10:32 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    I
    I'm thinking the 285s. I am worried about to going to big and having to live with it.
  16. May 30, 2024 at 5:58 AM
    Texans77
    Texans77 New Member
    2014 4Runner Trail Premium
    3 inch lift front. 2 inch lift rear
    I’m looking to do the same right now. I have 3 inch lift in front. 2 inch lift in rear. I still have stock rims. What offset did you have when you installed these tires? I would like to hold off on a viper cut for now. Do you think I can fit 285/75/17 without doing the viper cut and the stock offset
