First post…
Discussion in '5th Gen 4Runners (2010-2024)' started by USMA78, Jul 17, 2024.
  1. Jul 17, 2024 at 2:42 PM
    USMA78
    USMA78 [OP] New Member
    Marion
    2022 4Runner Limited
    Bought this ‘22 very recently. Came with 55,000 miles and I look forward to a great future with this beauty.
  2. Jul 17, 2024 at 3:36 PM
    T in Texas
    T in Texas New Member
    FEMA Region 6
    2024 Terra TRD Pro Terra - finally got it
    welcome and you will love it
  3. Jul 17, 2024 at 3:38 PM
    That is one sharp looking ride ya' got there. Nice find!
  4. Jul 17, 2024 at 3:44 PM
    Pentangler
    Pentangler Happy Member
    Welcome aboard.
  5. Jul 17, 2024 at 4:28 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome!
    Did you park your 4Runner in the living room?
  6. Jul 17, 2024 at 5:13 PM
    Bagman
    Bagman Dental Floss Tycoon
    Georgia
    Welcome!
  7. Jul 17, 2024 at 5:15 PM
    welcome
  8. Jul 17, 2024 at 5:50 PM
    BS67 New Member
    Welcome!
  9. Jul 17, 2024 at 5:55 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Welcome here @USMA78!
    You most definitely won’t regret the purchase
    Nice garage man
    @Dabigono lol
  10. Jul 17, 2024 at 9:32 PM
    TRDGrey2021
    TRDGrey2021 Guy in a truck
    2021 TRD Venture MGM
    Buncha Stuff
    Welcome!! Start saving. She is bullet proof but begs to be personalized!
    Race deck garage floor FTW!
  11. Jul 17, 2024 at 9:34 PM
    Trouble24
    Trouble24 New Member
    Steph
    Leavenworth, WA
    2024 4Runner TRD Pro
    Ceramic Tint Prinsu Pro Roof Rack 3” Westcott lift ARB Awning
    Welcome! Enjoy!
  12. Jul 17, 2024 at 9:35 PM
    HuskyMike
    HuskyMike New Member
    Welcome.
  13. Jul 18, 2024 at 2:28 AM
  14. Jul 18, 2024 at 5:25 AM
    Manhattan
    Manhattan New Member
    Welcome!
  15. Jul 18, 2024 at 5:30 AM
    Oakboro, N.C
  16. Jul 18, 2024 at 5:39 AM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    Is that a garage or your living room? Wheres the oil! Wheres the tools. Like the floor though. :D
  17. Jul 18, 2024 at 5:55 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Welcome....and nice windchime in the garage.
  18. Jul 18, 2024 at 6:57 AM
    TRDGrey2021
    Buncha Stuff
    I think the chime is for when the 4runner is meditating in that immaculate space.
    Serious garage envy.
  19. Jul 18, 2024 at 7:00 AM
    luc_who
    luc_who New Member
    Luke
    2024 TRD Pro
    Welcome... it looks like its been well taken care of.
  20. Jul 19, 2024 at 12:01 PM
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    Welcome fellow Limited owner from New Jersey!
    I recently added a hood deflector and blacked out some of the chrome...not all, just some ;)
    TimG
    mrmike7189 likes this.
  21. Jul 21, 2024 at 7:56 AM
    Ironguy New Member
  22. Jul 21, 2024 at 8:07 AM
    Nick4RNR
    Nick4RNR New Member
    Welcome and Congrats!
  23. Jul 21, 2024 at 5:45 PM
    Maximumdarkside
    J.
    Tennessee
    2014 4Runner Limited
    None yet.
    Welcome from TN!
