First 6th gen BUILD: 35's & Level Lift Kit on TRD Off-Road (Everest)
Discussion in '6th Gen 4Runners (2025+)' started by jwocky, Jan 23, 2025.
  1. Jan 23, 2025 at 7:54 PM
    jwocky
    jwocky [OP] New Member
    Tucson
  2. Jan 23, 2025 at 7:55 PM
    jwocky
    Tucson
    6th gen builds are looking great. Didn't take much, just 35's, level kit and some sweet wheels. Toyota definitely prioritized clearance on the TNGA-F vehicles.
    Yotaholic and Bagman like this.
  3. Jan 23, 2025 at 8:07 PM
    icebear New Member
    Oh, says he's in Plano, maybe I'll spot him sometime.
  4. Jan 23, 2025 at 8:09 PM
    jwocky
    Tucson
    I think Mjmotorsports808 is in Hawaii. 808 is Hawaii area code.
  5. Jan 23, 2025 at 8:27 PM
    icebear New Member
    Whoops! I just looked at the OP!
  6. Jan 23, 2025 at 8:29 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. New: 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, custom relocation of rear led pods to crossmember, exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. In progress/in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -wiring & connectors Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    ain’t look that big..
    let see 37’s :laugh:
    Yotaholic likes this.
  7. Jan 24, 2025 at 11:48 AM
    I have to see that color in person, I love green but it doesn't really do anything for me in the pics.
    Allowing room for larger tires is the best thing they did on this. I would run a 34x10.50 equivalent if I had one.
    djwantke likes this.
  8. Jan 24, 2025 at 11:56 AM
    wax poetic
    wax poetic Raking like a mofo
    21 Super White TRD OR
    I don't know man, I feel like between the huge tires and weight from sliders and other shit, that is a lot for a 4cyl. Maybe I'll be wrong but I def have my concerns
  9. Jan 24, 2025 at 11:58 AM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    My eyes aren't what they used to be but I certainly could live with this hue, but it would be good if they offered the 3rd gen green again...
  10. Jan 24, 2025 at 12:08 PM
    yeah it ain’t no slick @Captain Spalding green that’s for sure.
    allowing for larger tire capability really is one of the top 6th gen changes, I must say
  11. Jan 24, 2025 at 12:15 PM
    FourBelugas
    23 white ORP
    it is. They should have done it sometime during the 5th gen's 15 year run.
    Alas, better late than never.
    Trail Runnah likes this.
  12. Jan 24, 2025 at 12:58 PM
    Definitely in Hawaii
    Background aint plano
    jwocky[OP] likes this.
  13. Jan 24, 2025 at 7:42 PM
    Squatting Pigeon likes this.
  14. Jan 24, 2025 at 7:44 PM
    6th gen size growth over 5th gen is like 5th gen over 3rd gen.
    icebear and djwantke[QUOTED] like this.
  15. Jan 24, 2025 at 7:54 PM
    good comparison
    I’ve said before I love the smaller 1-3gen 4R, old Tundras, and little tacos. Even the badges are small. So good
  16. Jan 24, 2025 at 8:33 PM
    That is beautiful! Looks like a 3rd gen. I see Chevy still has that Cow Nosed Ray thing going on?
  17. Jan 24, 2025 at 9:05 PM
    I love this 83’ I just seen, like can we go back to this
    Toy4X4 likes this.
  18. Jan 25, 2025 at 9:54 AM
    Rick G.
    The Texas Hill Country
    2022 SR5 Premium 4WD
    Black hood looks stupid to me. I would at least have it painted to match. But then it will still have all those meaningless lines / humps/ bumps.
  19. Jan 26, 2025 at 5:52 PM
    jwocky
    Tucson
    CF hood would look better matched to Undergorund.
    underground-4runner-seibon-carbon-fiber-_3a5610e6245ec16f3ab08404464b7cbea2e19fac.jpg
  20. Jan 26, 2025 at 7:56 PM
    cuse93
    cuse93 Ice Station Zebra
    Toyota's selection of available 5th gen colors has always been pedestrian at best.
    For the last 15 years they've had the standard Rental Car Silver Metallic, Rental Car Blue Metallic, Rental Car Red Metallic, Rental Car Grey Metallic, Rental Car White Metallic, and Black.
    On top of the standard rental car colors they introduce a Pro color annually which falls into one of two categories.....
    1) Industrial/Public School Bathroom: cement, quicksand, lunar rock, army green, terra, underground, etc.
    or 2) Polarizing/Mountain Dew Commercial: voodoo blue, inferno, lime rush, solar octane etc.
    I'm not saying that I don't like a few of the Pro colors, I'm just saying overall the color palette was pretty lacking by most standards.
  21. Jan 27, 2025 at 3:04 PM
    That’s why they need the racer boi carbon fiber hood. o_O
    wax poetic[QUOTED] likes this.
  22. Jan 27, 2025 at 3:24 PM
    FourBelugas
    23 white ORP
    I predict the power will be there.
    What will be a wild card is if the additional rotational weight and contact patch end up requiring the motor to stay boosted more often, how fuel economy will be impacted. It is a well known fact that with motors like EcoBoost from Ford, when there is more than steady cruising load on the motor such as towing, hauling, etc the MPG take a sizeable hit.
  23. Jan 27, 2025 at 3:59 PM
    Definitely. The mpgs will suck with any additional weight or load. The Tacoma and LC have already proved that.
  24. Jan 27, 2025 at 4:40 PM
    I’m thinking such a small turbo means it will be constantly under boost with weight or with big tires.
    It will also be interesting to see how the new 8speed transmission will respond to 35s. Will it need a re-gear? Will it blow out clutch bands between gears? Will it upshift to 8th on the highway or stay or 5th, 6th or 7th? So many questions.
    And there is another variable with big tires. Is the extra electric boost from the hybrid system necessary to turn 35s reliably (or sufficiently, for that matter). Will the hybrid battery deplete on longer trips if its constantly pushing electric boost?
  25. Jan 27, 2025 at 5:13 PM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP, 2019 Audi RS5
    Magnuson Supercharger etc.
    https://www.youtube.com/watch?v=gahFGpmaKkI
    Same concerns in this vid with the tacoma. He says to maintain power it spends all its time in boost. Not necessarily bad if it was meant to handle it but it seems like Toyota's new high efficiency turbo engines are not even close to the same reliability as the 1JZ/2JZ.
  26. Jan 27, 2025 at 6:24 PM
    wax poetic
    Don't they also now have a smaller gas tank ... making it seem even sketchier to me to go too far off road with heavy weight
  27. Jan 27, 2025 at 6:37 PM
    cuse93
    let's see if Toyota starts denying powertrain warranty claims for vehicles running 35's
  28. Jan 27, 2025 at 7:24 PM
    Starts? They’ll do that right now.
  29. Jan 27, 2025 at 7:35 PM
    abso'freakinlutley
  30. Jan 27, 2025 at 7:37 PM
    Yes it’s 4 gallons smaller. Seems like a big mistake and annoyance.
