Finding All The Clearance Possible - Tires
Discussion in 'Wheels & Tires' started by Moon Landing, Oct 19, 2021.
  1. Oct 19, 2021 at 1:48 PM
    Moon Landing
    Moon Landing [OP] AFFTC 1967/68 Eddies Air Patch
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Got to nosing around this morning and while - as advertised - the 285's clear everything, I thought ahead to snow, mud and such and thought I'd try to get all the clearance between the front mudflap and tire as was possible. First, I did the heat gun work. Then laying on the COLD ASS drive(remember, I'm old;)) I found a way to gain even more room, and thus I was able to pull the mudflap even further back......we're not talking inches here, but every little bit counts, right.
    PhantomTweak, Roland, 2Toys and 2 others like this.
  2. Oct 19, 2021 at 1:53 PM
    So it fits on flat ground but what about when the suspension is flexing?
    Or I'm guessing that doesn't happen much.
  3. Oct 19, 2021 at 1:59 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Sorry, dad :rolleyes:
    4R21, Thatbassguy and travelinscout like this.
  4. Oct 19, 2021 at 2:04 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    If you want to know if it’s going to rub, either put it in full lock and try to reverse it or put it in full lock and try to drive over a bump or a curb.
  5. Oct 19, 2021 at 2:06 PM
    Have you tried maxing the caster out yet?
    Roland likes this.
  6. Oct 19, 2021 at 2:09 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    That was in reverse and it was at the point where the tire comes closest to the mudflap. Am I missing something?
  7. Oct 19, 2021 at 2:11 PM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    Nope. That’s about as close as mine is with body mount chop and removal of the front mud flap.
  8. Oct 19, 2021 at 2:12 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Westcott maxed everything out when they installed their body lift. However, with the build, I've lost some of the 3 inches it provided. I'm at a point where I won't know what reality is until the rubber meets the trail. ;)
    Roland, 2Toys, Thatbassguy and 2 others like this.
  9. Oct 19, 2021 at 3:52 PM
    I didn't remove mud flaps on my TRD ORP and Limited didn't have mud flaps (has a flat plastic flap kinda thing). I don't have a heat gun but this is the cheap utility torch I used to push the plastic.
    nimby and Thatbassguy like this.
  10. Oct 19, 2021 at 3:59 PM
    If you find you still rub on the mudflaps when flexed, Rokblokz are cut around the body mount to allow a little extra clearance.
    Once I got a good alignment, my 285's never rubbed until I bottomed out while turning. This almost never happens, so I left it alone. Then, I bottomed out while turning on the 295's and it pretty much tore my mudflap clean off. :rolleyes:
  11. Oct 19, 2021 at 4:55 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Ouch!
    Just returned from a trip to town(30 miles or so with desert drainage - meaning most every intersection has whoop's)and with the 285's aired, it's beyond obvious the Runner needs rear springs. I'm not surprised, but am a little disappointed Toyota went, so weak! Now is it possible to strike a balance or will fixing it, load the fronts? Right, is never easy :)
  12. Oct 19, 2021 at 5:01 PM
    The good thing is that there are plenty of options for rear springs. I went with Bilstein +400# springs and they're pretty good. I think they could use more damping, but they handle the load well.
    I believe Dobinson and others have multiple options for rear springs as well.
    Roland likes this.
  13. Oct 19, 2021 at 5:10 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Thanks for that info.
    I'm disappointed with Eibach. They say they open a 7:30a.....called around 9:30a and was told no one was in, yet. Left message and no one returned the call. Called them back at 4:40p or so to find out they close at 4:30P. Talk about bankers hours.......or less!
    Edit: @Thatbassguy thinking out loud here. Because I don't want to upset the front end....tho it may already be? Thinking, I may bag the back. That would give me total control on how much I load the fronts. And, if it all fails? Then I'm going BIG TIME suspension upgrade, and that'll be that.
    Roland, 2Toys and Thatbassguy[QUOTED] like this.
  14. Oct 19, 2021 at 5:30 PM
    Bags could be the ultimate solution. I like the idea of being able to adjust for your load. I'm pretty sure Firestone makes a pretty cost effective setup for us. Of course, you can hook it into onboard air and get really fancy with it if you don't mind the extra cost. :)
    Sucks about Eibach. I've heard a lot of good feedback on their products.
    Roland likes this.
  15. Oct 19, 2021 at 5:34 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Probably wouldn't start out that way, just to see how it works. Then again, they're so inexpensive and light, that carrying a spare wouldn't be an issue. Wait!! You're convincing me.......:yes: :hattip: that's it.....I'm gonna do it.
  16. Oct 19, 2021 at 5:36 PM
    kwill
    kwill New Member
    Have you considered Sumo Springs?
  17. Oct 19, 2021 at 5:36 PM
    I'm always happy to help people get rid of their extra money! :rofl:
    :spending:
  18. Oct 19, 2021 at 5:37 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Humo? jk No sir, but I'll search them. Thanks!
    Roland and Thatbassguy like this.
  19. Oct 19, 2021 at 5:52 PM
    What are your thoughts about suggest full suspension solution where the kits have shocks having valves tuned to hold even at 2in lifted in back or even have HD spring option?
    Spend once - Cry once thing?
    I could be wrong, but I was thinking when stock height shocks are stretched it might be sitting at soft tune and it will not go to hard valving section until its compressed quite far in? Please correct me if that's a wrong theory.
    Roland and Thatbassguy[QUOTED] like this.
  20. Oct 19, 2021 at 6:14 PM
    kwill
    kwill New Member
  21. Oct 19, 2021 at 6:28 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
  22. Oct 19, 2021 at 6:37 PM
    kwill
    kwill New Member
    Yup. I had them on a 2019 Tacoma and have them on my 2021 4Runner. I pull a light trailer but it's tongue heavy and the Sumo Springs are perfect. They're easy to install, too.
  23. Oct 19, 2021 at 6:47 PM
    I think you're right. But, airbags are just another way to deal with extra weight.
    I don't think the stock shocks are position sensitive. Most of the aftermarket shocks seem to be designed for a certain range of lift, so they probably are.
    I chose heavy load springs because a lot of the weight I added is always in the 4Runner.
    Roland, kmeeg[QUOTED] and SlvrSlug like this.
  24. Oct 19, 2021 at 8:08 PM
    Something I was just thinking about... Airbags can be adjusted to whatever load you're carrying on any day. Heavy load springs are always the same stiffness. So, airbags really seem ideal for folks who don't keep everything in their vehicles all of the time.
    Even with adjustable shocks and coilovers, it will always sag as you add weight. And, heavy duty coils might be harsh when the vehicle is not loaded.
  25. Oct 19, 2021 at 8:38 PM
    Roland
    Roland New Member
    No BMC - No mud flap heating, some decent off-roading in Moab, needed full lock quite a bit. No rubbing, just a good alignment.
  26. Oct 20, 2021 at 6:08 AM
    Are you still running the stock rear shocks?
    Roland likes this.
  27. Oct 20, 2021 at 6:18 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Yup.........FOX '21 Pro OEM
    Roland likes this.
  28. Oct 20, 2021 at 6:25 AM
    Ah, gotcha.
    If you were running the stock Tokico shocks, I was going to suggest trying an aftermarket rear shock with a firmer valving. You probably don't want to get rid of those Fox shocks.
    Sounds like an airbag or a stiffer spring is the way to go.
    PhantomTweak and Roland like this.
  29. Oct 20, 2021 at 6:34 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    After sleeping on all kinds of input from various folks here, I'm convinced air bags are the best route to take. They may or may not have issues(puncture)but if proper use guidelines are followed I think they'll be fine(never run under 5#'s). Plus, they'll allow for incremental adjustments, which is a BIG plus. imo
    SlvrSlug, Roland and nimby[QUOTED] like this.
  30. Jul 22, 2024 at 9:12 PM
    Justkelvin
    Justkelvin New Member
    2023 TRD off road premium
    Do you have any lift in the rear
