Fang Lights
Discussion in '5th Gen 4Runners (2010-2024)' started by Pupsn4runnerlife, Mar 3, 2024.
  1. Mar 3, 2024 at 9:33 AM
    Pupsn4runnerlife
    Pupsn4runnerlife [OP] New Member
    Jen
    2021 SR5
    Eibach Lift, Level 8 Slingshot Wheels, Cali raised cat guards
    Has anyone installed these fang lights?
    My question is, instead of piggy backing on a fuse, why can't I just open the loom, peel back the insulation, solder and splice the fang light into the OEM circuit? Same with the raptor lights. Since they're just LEDs....how much current could they possibly take? I wouldn't think they'd need their own fuse.
    ecoterragaia likes this.
  2. Mar 3, 2024 at 11:38 AM
    Sure, why follow the directions so they work properly (and safely). Do it your way!
    ...let us know how that works out for you.
  3. Mar 3, 2024 at 12:39 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Because that's just like replacing a fuse that's blown with a higher amp rating to keep it from blowing. You'll only risk blown fuses at best and an electrical fire at worst, YMMV......good luck.
  4. Mar 3, 2024 at 2:49 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    It depends on how the lights themselves are designed. LEDs are diodes, which means they'll take all the current they can get until they burn up, unless there's another load (like a resistor) in series to limit the current. That could be included in the lights themselves, or they could assume you're providing it externally.
    ecoterragaia and Steely123 like this.
  5. Mar 4, 2024 at 5:11 AM
    Pupsn4runnerlife
    Jen
    2021 SR5
    1. Not sure who pissed in your cheerios, but I hope your day got better.
    2. NONE of the aftermarket products I’ve purchased have ever come with instructions.
    3. Forums are to ask questions and get ideas from others who have installed similar mods. If you haven’t done this, why even bother responding.
    4. Thank you for the vote of confidence! I did do it my way and it worked out!
    5. ESPERO QUE TENGAS UN EXCELLENTE DIA!
  6. Mar 4, 2024 at 5:23 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    So, if none of them never came with instructions, that means that all of them came with instructions?
  7. Mar 4, 2024 at 9:20 AM
    frios
    frios New Member
    2021 4Runner TRD Off Road Premium
    ノーマル
    I wonder if there's a way to wire them them so that they only come on as amber turn signals and not as DRL/Turn combo, assuming it even has amber switchback mode?
  8. Mar 4, 2024 at 1:01 PM
    Pupsn4runnerlife
    Jen
    2021 SR5
    Good question. I'm not sure.
  9. Mar 4, 2024 at 1:01 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    From the pictures I have seen, it seems they look more like tusks than fangs.
