Fang Lights with Morimoto XB LED Headlights Install
Discussion in '5th Gen 4Runners (2010-2024)' started by catfish52, Jul 2, 2024.
  1. Jul 2, 2024 at 9:07 AM
    catfish52
    catfish52 [OP] New Member
    2016 T4R Limited
    Does anyone know how to wire fang lights in with Morimoto XB LED headlights? Specifically wondering which wire to splice the turn signal control wire into.
    Also, a rep from 4RunnerLifestyle told me to tap the power into the power wire for the headlights, but the video I found wires them directly into the fuse box.
    Any help would be appreciated.
  2. Jul 3, 2024 at 2:54 PM
    Parish
    Parish New Member
    Update: drl wire didn’t work.
    https://www.morimotohid.com/core/me...4PKjJJl7KWZkWmPjsC9TCeogrhf7UwahAAzUYYimzFbvY
    From 4Runner lifestyle:
    Connect the Fang Lights to the Morimoto DRLs
    Splice Connections: You will need to splice the wires from the Fang Lights into the DRL wiring of the Morimoto headlights.
    Positive Wire: Connect the positive wire of the Fang Lights to the positive DRL wire of the Morimoto headlights.
    Negative Wire: Connect the negative wire of the Fang Lights to the negative DRL wire of the Morimoto headlights.
    Use Connectors: Use T-taps, butt connectors, or solder and heat shrink to make secure, weather-resistant connections. Ensure all connections are tight and well-insulated to prevent shorts.
  3. Jul 3, 2024 at 2:55 PM
    The guy who makes an install video for fang lights (and shares it on YouTube & 4Runners) will be a hero to many.
    catfish52[OP] likes this.
  4. Jul 3, 2024 at 3:32 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
  5. Jul 3, 2024 at 4:56 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Until some fang lights do what fang lights sometimes do.
  6. Jul 3, 2024 at 8:51 PM
    catfish52
    2016 T4R Limited
    Problem is, none of the wires in the Morimoto DRL harness are labeled AFAIK.
  7. Jul 3, 2024 at 8:52 PM
    catfish52
    2016 T4R Limited
    Yeah, I saw this one. Problem with this one is the Morimoto doesn't have a turn signal bulb. So I still don't know which wire to splice the fangs into.
    Parish likes this.
  8. Jul 3, 2024 at 9:19 PM
    catfish52
    2016 T4R Limited
    I think they heard us. 9 hours old, as of now.
    https://youtu.be/vTqpiiU_wb0?si=5t_PX44i1WM40Cf-
    Parish likes this.
  9. Jul 4, 2024 at 2:29 PM
    Parish
    Parish New Member
    I looked are wiring diagram from morimoto but the install updates from 4Runner lifestyle didn’t work for me ‍♂️
  10. Jul 4, 2024 at 2:36 PM
    Parish
    Parish New Member
    They told me to splice into drl but that didn’t work. I was skeptical that it would, since that’s a constant line too. I’m thinking that it would work if you connect the non sequential lighting connectors and splice into that.
  11. Jul 4, 2024 at 2:50 PM
    Parish
    Parish New Member
    I’m thinking if you connect the plugs to disable the sequential light sequence and tap into that line it may work. I don’t want to lose the sequential tho.
  12. Jul 7, 2024 at 9:22 PM
    Smokey 24’ TRD PRO
    Smokey 24’ TRD PRO New Member
    NY
    ‘24 4R TRD PRO
    So did I just wate my money on the Morimoto XB LED Gen 2? Wanted to have it go with the AJ fangs white/sequential. Would it work better witht the stock headlights with different bulbs?
