Fang Lights Questions.
Discussion in '5th Gen 4Runners (2010-2024)' started by WhiteRhino4R, Jan 17, 2024.
  1. Jan 17, 2024 at 9:13 PM
    WhiteRhino4R
    WhiteRhino4R [OP] New Member
    White4Runner
    Hey everyone,
    I just installed my fang lights and did all the necessary instructions. Now my left blinker goes on with the right fang lights and vice versa. The other thing is that now my blinker, blinks faster than normal.
    Any suggestion as to what I should do?
    I changed the t-tap already.
    Any advice would be appreciated.
  2. Jan 17, 2024 at 9:18 PM
    There was a fang light issue thread just a few weeks ago.
  3. Jan 17, 2024 at 9:26 PM
    WhiteRhino4R
    White4Runner
    Do you have the link? :)
  4. Jan 17, 2024 at 9:55 PM
    No, sorry. Maybe if you go back a few pages on the threads it will be there. As I remember, the gentleman had similar issues.
    Best wishes
  5. Jan 17, 2024 at 10:24 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey OP @WhiteRhino4R
    Thanks Slopemaster
    I made a fang light thread about an issue, and posted recently how I resolved the issue. May be the thread he's thinking of.
    Either way, I have a decent amount of experience with front end lighting.
    I thought if your blinker (light bulb) blinks fast, it means you have a dead bulb somewhere or a bulb about to fail? Sound like it doesn't like the connection or voltage
    https://www.4runners.com/threads/op...ash-switch-both-intermittently-failing.34417/
    Slopemaster likes this.
  6. Jan 18, 2024 at 11:45 AM
    A fast blinker means one of two things:
    1) A dead bulb.
    2) Hyper flashing because of voltage issues. That means the bulb isn't dead, but you'll need a resistor (possibly).
    djwantke likes this.
  7. Jan 18, 2024 at 1:22 PM
    @WhiteRhino4R
    I wish I had the answer for you guys, interested in the resolution.
    Here's links to my original install, not super helpful but I have many more photos
    https://www.4runners.com/threads/inj-vs-inj-no-3.31484/#post-447723
    https://www.4runners.com/threads/what-have-you-done-to-your-5th-gen-4runner-today.2261/page-740#post-40155
    The other day I switched which cabin fuse I'm using for multiple things. Tried the IGN 10A again, works flawless like many have confirmed. I'm even running two piggy back fuse holders dbl'd up :devil:. (I got a lot of 12v running)
