Falken Wildpeak at4w?
Discussion in '5th Gen 4Runners (2010-2024)' started by 124runner, Jan 31, 2024.
  1. Jan 31, 2024 at 10:25 PM
    124runner
    124runner [OP] New Member
    so apparently the falken wildpeak at3w which many liked is now discontinued and i can’t find them, it’s replaced by the at4w. i am scared that they might have somehow made the at4w worse. there are no reviews since it is so new. What do you guys think, should i just buy the at4w.
  2. Jan 31, 2024 at 10:36 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
  3. Feb 1, 2024 at 5:21 AM
    djdaves
    djdaves New Member
    SEPA
    2015 4runner SR5
    lift, wheels, tires, stuff.....
    I can't imagine them getting worse. Especially if they were that popular. IMO
  4. Feb 1, 2024 at 5:26 AM
    broken-giver
    broken-giver BFD
    huh! Didn't know they were discontinued. I went with KO2 for the looks but they were a close second.
    Naville likes this.
  5. Feb 1, 2024 at 5:36 AM
    Agoldxj
    Agoldxj New Member
    Central Pa
    2022 super white Sr5, 2009 Tacoma 4.0
    I was just thinking about getting these for my Tacoma to replace my duratracs. We have the at3s in her 4 runner and they ride nice and quiet.
  6. Feb 1, 2024 at 7:05 AM
    HuskerRunner
    HuskerRunner I joined 2.5 years after Rick G
    O,NE
    2023 SR5P
    Taco to 4R Mod
    What if you bought AT3s and 2 months from now all the reviews you read are how much of an upgrade the AT4s are? If you have experience with a brand and like them, I say pull the trigger on the new offering. Very few companies are in the business of effing up the new rollout of already good product. (Turd Gen Tacomas being an exception but I digress).
  7. Feb 1, 2024 at 7:41 AM
    I wonder if KO3 has better water evacuation characteristics than AT4W to avoid hydroplaning.
    I also see more siping on KO3 that could help winter traction.
    Not sure, I'm not a tire tech or work for them :p
    Naville, captrussia253 and kolter45 like this.
  8. Feb 1, 2024 at 9:50 AM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    I'm running KO2's on my Venture and my Land Cruiser and couldn't be happier. That said, the Wildpeaks are excellent too and if I wasn't running KO2's (more out of familiarity vs. them being better than the Wildpeaks), I wouldn't hesitate to go with the AT4 Wildpeaks.
    Falken is known for quality and durability. IMHO - no way is Falken going to replace a current generation tire that is know the world over (for years) as being superb (AT3) with something that isn't improved (AT4). I wouldn't hesitate to go with the AT4 for that reason.
  9. Feb 1, 2024 at 10:03 AM
    2016SR5P
    2016SR5P New Member
    Massachusetts
    2016 SR5P 4WD
  10. Feb 1, 2024 at 11:03 AM
    Linuxr
    Linuxr New Member
    VA
    I just ordered a set of 5 of the 4w got them for $225 per tire mounted and balanced.
  11. Feb 1, 2024 at 11:27 AM
    CRasch505
    CRasch505 New Member
    Chris
    5th Gen 4Runner ORP
    Fifteen52 Analog HD's, Nitto Terragrapplers, 1" spacer lift front, ceramic on all glass.
    That's a good deal. Where from?
  12. Feb 1, 2024 at 11:38 AM
    Linuxr
    Linuxr New Member
    VA
    A local shop in Maurertown va. I have bought tiers from them for many years. The place looks like it's ready to fall down but they have the best deals of anywhere.
    CRasch505[QUOTED] likes this.
  13. Feb 1, 2024 at 11:51 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    "tire water evacuation, tire siping" pretty smart non tire tech you are
    kmeeg[QUOTED] likes this.
  14. Feb 1, 2024 at 11:55 AM
    Rocko9999 and kolter45 like this.
  15. Feb 1, 2024 at 11:57 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    For the record, my duratracs are super loud and I will not be buying them again
    Harringbr99 and djwantke like this.
  16. Feb 1, 2024 at 11:58 AM
    kolter45
    Denver
    I will not be buying them till reviews hit and stick. I hope I dont get a flat & have to replace them with a tire they no longer have...:bananadead:
    djwantke likes this.
  17. Feb 1, 2024 at 12:06 PM
    I sold my Duratracs and put to do not buy list. But they were the best winter traction tires I had compared to BFG KO2/ FLK AT3W/ N Terra Grappler / C Terrain Contact/ Toyo OC AT3.
  18. Feb 1, 2024 at 12:14 PM
    I'm just gunna put this here :p
    kolter45 likes this.
  19. Feb 1, 2024 at 12:33 PM
    Pretty good traction in the dirt but I managed 3rd gear wheelspin on wet pavement on them and that was before the blower. They got loud even with regular rotation. Never again!
    kmeeg[QUOTED] and djwantke like this.
  20. Feb 1, 2024 at 12:41 PM
    When I was tire shopping local tire tech shop owner famously told me he calls Duratrac's "inner tubes with thread on it"
  21. Feb 1, 2024 at 1:06 PM
    kolter45
    Denver
    :cheers:
    Discount Tire Direct is having a sale - $80 off michelin - $100 off pirelli
    w w w discounttiredirect com/promotions
  22. Feb 2, 2024 at 6:03 AM
    Jmb0351
    Jmb0351 New Member
    Jon
    I have about 3k on my stock size Mickey Thompson Baja Boss's and can't say enough great things about them. Game changer during our last snow storm. Quiet, good ride, love them!
    djwantke[QUOTED], MEski4x4 and kmeeg like this.
  23. Feb 2, 2024 at 7:42 AM
    HazOpRed
    HazOpRed 22' TRDOR
    My body is ready
  24. Feb 2, 2024 at 8:24 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I was reading tire reviews for Falken Wildpeak AT3W’s and there were several saying they wore out much faster than expected and got louder with more miles. That said, they all seemed to be reviews for bigger and heavier trucks. Anybody notice unusual early wear or noise with AT3’s on 4Runners?
  25. Feb 2, 2024 at 8:38 PM
    backpacker
    2023 TRD ORP
    Mine have a little over 8k miles with no excess wear or increased noise. They're still heavy, though.
  26. Feb 2, 2024 at 9:36 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I have 22k miles on the stock nitto and no noise. When they’re done I’ve been contemplating between falkens and toyos. I wonder how they compare to the nitto terra in terms of road noise. But also I have a Gobi rack and no issue at all regarding noise despite having read many people complaining about wind noise before I bought it. I wonder if the trd exhaust is the reason I don’t hear tire and wind noise though. I’ve been debating on doing the mod to make it as quiet as the non trd exhaust but then I’m afraid I’ll start hearing my Gobi rack and my tires.
  27. Feb 3, 2024 at 7:31 AM
    Gobi no rise is pretty damn quiet. I'm sure the no rise option helps with that a ton. I don't hear mine either.
    But I do hear my KO2's getting louder as they age.
  28. Feb 4, 2024 at 3:30 PM
    matoolie
    Michael
    2021 Lunar Pro
    I noticed a very slight increase in noise when comparing AT3W’s with less 5k to ones with about 50k. But minor and not very obvious.
  29. Feb 4, 2024 at 3:57 PM
    This guy just made a video comparing the two:
  30. Feb 4, 2024 at 6:39 PM
    auspilot
    auspilot Old Member
    2020 TRD OR
    Dobs IMS, lots of small stuff
    My SL loads have gone from 13/32 (new) to 7/32 after ~30k miles. At that depth I'd be a little nervous running rocky trails. So it seems to me like fairly fast wear although I don't have much experience with other AT tires for comparison. I do like their on-road manners, and the Tire Rack testing seems to confirm that. Noise when new was not noticeably louder than the stock all season tires, and they may have got louder since but not significantly and not enough for me to notice. At the current tread depth I don't want to run them much more than maybe 10k more miles but I do like them and plan on replacing with AT4Ws, which Falken claims should have better tread life.
