Faded plastic trim and mud flaps?
Discussion in 'Detailing' started by calebw10, Sep 19, 2023.
  1. Sep 19, 2023 at 10:49 PM
    calebw10
    calebw10 [OP] New Member
    Caleb
    2014 4Runner SR5
    Anyone got any solutions to faded black plastic on 5th gens? Mud flaps and plastic mirror trim are the worst parts. This doesn’t come off after a wash.
  2. Sep 20, 2023 at 1:00 AM
    There are some products that “moisturize” the plastic, but it’s not a permanent solution. Have to reapply after washing.
    08TXRunner likes this.
  3. Sep 20, 2023 at 5:03 AM
  4. Sep 20, 2023 at 7:37 AM
    ive done the "torch" method and was absolutely amazed at the results. It look brand new
  5. Sep 20, 2023 at 8:25 AM
    dosomeplowin
    dosomeplowin New Member
    '24 ORP
    If you're wary of flame, I really like Wolfgang Exterior Trim Sealant - it lasts longer than Aerospace 303, etc. in my experience.
  6. Sep 20, 2023 at 8:27 AM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i’ve heard the fade comes back worse if the heat method is used. how’s it holding up for you guys?
    Bodie the Dog likes this.
  7. Sep 20, 2023 at 9:37 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Don't do this. It simply brings the plasticizers to the surface and will soon fade even worse than before, making the plastic even more brittle.
    Bodie the Dog, LCJ77 and 08TXRunner like this.
  8. Sep 20, 2023 at 9:38 AM
    I purchased Solution Finish but haven't tried it.
    2023_lunarrock-ORP likes this.
  9. Sep 20, 2023 at 9:40 AM
    Rocko9999
    2011 Limited
    I have had really good luck with Cerakote wipes. It has held up for 6 months on my cowling and other trim that was sun bleached. Also brought back wife's 2005 Corolla cowling. Wear the gloves-the stuff stinks and you don't want it on your hands. Also, make sure the plastic you are treating is clean, dry and relatively cool.
  10. Sep 20, 2023 at 10:21 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    WOW!! That heat method using a butane torch looks like it really works. Primarily the weather and parking outdoors and time are the likely culprits. But I've also found that the detergents used by some car washes can add to the problem. In any case, once the black is restored and/or already in good condition, here is what I've used over the years for black trim:
    MUD FLAPS: I just use a good rubber dressing. Same as I use on the tires. Griot's Garage makes a good rubber dressing. And it lasts a long time. I use the one that dries to a MAT finish versus the shiny finish. Just looks like new rubber when dry. And stays that way over many washes.
    SMOOTH HARD BLACK TRIM: I just use a good quality wax. Seems to do the job.
    GRAINED HARD BLACK TRIM: Using wax seems to produce a bit of an uneven finish. Even though this product is 20+ years old, I still find it works well on the black plastic trim that has a grain type, rough look. Nu-Vinyl just works for this application.
    SOFT BLACK RUBBER TRIM: Like door gaskets. I've found Black Back works great for both cleaning and restoring for this application. It comes as a cream. With a thin piece of cloth (2" gun cleaning patches work great for this) just rub it in to the door gaskets. You won't believe the crap that comes off. LOL Gaskets just look like new rubber.
    Of course, you'll need to check the condition after car washes, but the protection should last for a while. And, Nu-Vinyl and Black Back are both 20+ year old products. So there may be better, updated products available today. But it always seemed that hat black plastic trim needed it's own maintenance schedule. LOL
  11. Sep 20, 2023 at 10:43 AM
    TRDSD
    2019 TRD Off Road Premium
  12. Sep 20, 2023 at 11:05 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    There are enough products out there that would give you the desired results with varying degree of longevity. But they are temporary.
    The heat method,, I do not recommend. It simple releases the oils from the plastic and will eventually make them an eyesore.
    The best bet is to replace them. Flaps are cheap and easy.
    I ve used Turtle Wax hybrid Graphene Acrylic on the plastic cover on the rear bumper and it has held up well for last 5 months. It does attract a lot of dirt .
  13. Sep 20, 2023 at 1:08 PM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    THANKS!!! Good to know.
  14. Sep 20, 2023 at 1:53 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    I use Maguire's Ultimate Black. As others have mentioned, it's temporary. Lasts maybe a month and then you get the chalky white again and have to reapply. Fine for me.
  15. Sep 20, 2023 at 10:51 PM
    2023_lunarrock-ORP
    2023_lunarrock-ORP Pistolero
    Brandon
    Pacific Northwest
    2023 lunar rock orp
    rickystl likes this.
  16. Sep 21, 2023 at 7:33 AM
    2016Pro
    Just use the 9 things that are recommended on here all at once lol.
    rickystl, Steely123 and djwantke like this.
  17. Sep 21, 2023 at 8:17 AM
    Rocko9999
    2011 Limited
    I bought a bottle and used it on my 2014 Tundra and 2005 Corolla- did not last. Followed the directions to a T. Looked great for 1-2 weeks. Then the first rain or mist, it ran and streaked, then lost it's effect. Was a bummer, had heard good things.
  18. Sep 21, 2023 at 8:26 AM
    2023_lunarrock-ORP
    Brandon
    Pacific Northwest
    2023 lunar rock orp
    I used it on my wife’s old Acura tl and it worked very well. We sold the TL about 4 months after applying the solution finish, but it still looked just as good as the day I applied it. I actually didn’t have high expectations for the product, I’ve used a lot of different products on her horribly faded trim and solution finish was the best by a large margin.
  19. Sep 21, 2023 at 11:29 AM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 260K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    I had this issue with my old Xterra. I highly recommend DupliColor Trim & Bumper Paint. Follow the prep instructions for the best outcome. Here's a pic where I had popped off the top bumper cover, painted it, and replaced it for a side-by-side comparison:
    The whole truck done. This wasn't even right after I painted the trim, this is a few years later when I sold it. Note the air dam, I don't think I ever got around to painting it.
    rickystl and Rocko9999 like this.
  20. Sep 21, 2023 at 11:48 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Two words my friend, mudflap deletes :p
    Henry J likes this.
  21. Sep 21, 2023 at 11:52 AM
    Bodie the Dog
    Bodie the Dog Danger Ranger!
    2016 TEP, 1994 SR5
    Shrockworks sliders & rear bumper, Toytec 3/2 lift, ARB diff mod, 8 pod RGB LED's, RCI steel front skids, Big Sky katana rack, Reese roof rack, cool stickers.
    Charlievee and Rocko9999 like this.
  22. Sep 21, 2023 at 12:41 PM
    Rocko9999
    2011 Limited
    Bodie the Dog[QUOTED] likes this.
  23. Sep 23, 2023 at 10:51 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    I've found that vehicles with lots of black plastic trim require regular applications of protection. Maybe every 3-4 washings. I scheduled treatment on the black trim at the same time I did the tire dressing. A good example of lots of black trim is the FJ Cruiser. Here is a pic of my 2010 with 160K just before I traded it in for the 4R. It will likely stay this way, but requires regular applications. At least, that's been my experience.
  24. Sep 26, 2023 at 1:34 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    You guys will laugh but this has worked for me for years. I didn’t believe it until I tried it.
    Boiled Linseed oil mixed with mineral spirits. Roughly 2 parts oil, 1 part spirits.
    Been using it on my Dodge trim for over a decade. It has the Sport Pkg with almost all black trim and very little chrome. It hasn’t harmed the plastic or paint.
    I use an old plastic vitamin bottle for the container mix, I’ve been using the same mix/bottle for over 12 years. Just put a little bit on a rag and wipe it on the plastic, do the whole car then go back and wipe off any excess. I’ve have probably done the truck a dozen times over the years and it seems like it is lasting a very long time (>year) the more I have applied it. It works and looks great.
    Used it on my 2nd gen as well, haven’t used it on the new 4R yet as it is still new(garage queen/mall crawler).
    The only thing you should be careful of is the used rags. Linseed oil on rags in a trash could spontaneously combust under the right conditions. To be safe I put the rags outside my shop with a rock on top to keep them from blowing away for a couple days to dry out.
  25. Sep 26, 2023 at 1:38 PM
    Henry J
    Sacramento Ca
    I only use chemical guys in mine now. Visited their store in Torrance and watch their videos, shit is soooooooo good.
