Factory front tie down points
Discussion in '5th Gen 4Runners (2010-2024)' started by afret, Feb 28, 2022.
  1. Feb 28, 2022 at 10:23 AM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
    Can these be used as recovery points if the two points are connected with a bridle if in the extremely rare chance I get stuck somewhere?
  2. Feb 28, 2022 at 3:27 PM
    The toyota manual states they can be used for towing on flat surfaces, for a limited mount of miles. With the stipulations I remember reading in the manual, I would be wary of using them as recovery where any significant amounts of tugging is required to get the vehicle moving are involved (such as when using a snatch strap).
    Trail Runnah likes this.
  3. Feb 28, 2022 at 5:08 PM
    afret
    North Idaho
    So I wonder what they do when a basically stock 4R gets stuck somewhere? Maybe try and pull from the back?
    Looking at the Treaty Oak recovery point that is held by 2 bolts to the frame, one bolt screws directly into the frame and the second bolt screws into a flat nut held on by a rod that you put inside the frame. That hole actually goes through both sides of the frame so I wonder why they don't just use a long bolt that goes all the way through the frame and use a large thick washer and nut instead?
  4. Feb 28, 2022 at 6:24 PM
    polyguy79
    polyguy79 New Member
    LA County
    2021 White Runner ORP
    RCI aluminum skids (front, trans, TC, and gas), RCI steel sliders 20 degree no plates with kickout, Treaty Oak recovery points, LFD stainless crossbars, Greenlane ladder, Toyo Open Country AT III, Bilstein 5100s, OME (front 2” lift) and Eibach (rear 1”lift) coils
    I have the Treaty Oak recovery points installed and these are very beefy and there are no concerns on my end about how they bolt into the frame. These are plenty strong to hold up to dragging someone’s butt out of trouble (or your own!).
  5. Feb 28, 2022 at 8:17 PM
    If you need to use them, the bridle would be the preferable way. And even than no side loads, and no getting a running start with the tow vehicle.
    I have the Apex Overland Recovery points on mine, which I like. Similar to the Treaty oak, they just mount differently. IIRC from the install, they have 4 bolts per side.
    Wes72 and semprenissart like this.
  6. Feb 28, 2022 at 8:24 PM
    The factory welded hold downs look pretty good to me. Curious if there’s actual evidence of them failing during a pullout.
  7. Feb 28, 2022 at 8:47 PM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I ordered the Apex Overland recovery points the other day. Should receive them later in the week. They look like a good and safe option for those who do not have an aftermarket front bumper
    Wes72 and Trail Runnah like this.
  8. Feb 28, 2022 at 9:05 PM
    Once you look at them carefully, you notice they arent welded to the frame proper…they’re actually welded to the crossbar under the radiator. The problem there is that the crossbeam structure is sideloaded.
    Also, the loops themselves are being side-loaded, since they have a downward bend. Any pulling will impart a bending force to the loop portion.
    Toyota say’s it’s good enough for towing short distances on paved roads, but that’s about it.
    If you tug too hard, that cross beam where the loops mount to will bend forward towards the front of the vehicle. But since the loops are welded in a way that effectively applies torque to the crossbar, I can just as easily imagine the crossbeam twisting. In a best case scenario, only the loops themselves would bend out straight.
    However, that is only assuming that cross beam is in pristine condition. On most 4runners that crossbeam is the first thing to completely rust out. Ive seen older 4runners with them almost entirely rotted out. So, the reality is that on older 4runners, that whole cross beam is gonna get torn out.
    If you sit and look at it, it’s really a weird setup for any type of anchoring point.
  9. Feb 28, 2022 at 9:25 PM
    You make some good points. I’ve looked at them but never studied the structure. My plan is to avoid getting into a situation where I need a tow. ;)
  10. Feb 28, 2022 at 9:28 PM
    Regarding the rear recovery, yes I would say the rear hitch (using a hitch/shackle setup in the receiver) is the safest way to attempt a recovery. Of course, the hitch is rated to tow 5,000lbs, so that should still be part of the consideration. I dont know what that tow rating means related to ultimate strength before things get tweaked, but it still seems more stout that the front hooks. Also keep in mind, if you are being recovered (in off road situations) using the front loops, you’ll be pulling yourself INTO the very thing that got you stuck (lots more force needed to pull you through it) Usually this would be a bad idea lol.
    So Id stick to recovering from the rear. Just make sure you are in neutral before getting (gently) snatched out.
    Regarding the treaty oak anchor points and the rod that goes through the frame…. My guess is that rod is sized to be the exact same width of the box section frame,and that the bolt essentially screws down pressure onto the rod, instead of the walls of the frame. If you used just a through bolt with a nut/washer on the other end, you could end up crushing the two sides of the box section frame towards each other.
    The only reason I know is because my warn bumper had a through-bolt. As I tightened the nut, my torque wrench did not click when I thought it should have. I stopped to look and realized it would never click, because it would just end up squashing the two sides of the box closer and closer. Thankfully I realized this before I did any damage.
  11. Feb 28, 2022 at 9:32 PM
    I just changed the oil last night…gave me an opportunity to spend an unnatural amount of time just looking around down there lol :laugh:
    part of that time was spent looking at that crossbeam and making sure the half-gallon of Woolwax I applied to JUST that part, was still doing its job haha
  12. Feb 28, 2022 at 9:41 PM
    Are you referring to the crossmember that supports the radiator and has that foam that some people have had corrosion problems with?
    Last year when I was doing my oil change I raised the foam in a couple of places and it all looked good, like new. Fortunately I live in an area where vehicle corrosion is not a problem.
  13. Feb 28, 2022 at 9:47 PM
    Yup, that’s the one. I’ve heard some recommend to take the foam off to let that crossbeam dry out. And while I agree that foam may be a source of corrosion due to trapped moisture, I decided instead to leave the foam on, but I saturated it with woolwax (in addition to coating the entire crossbeam inside and out). I live in salt spray central, and I was afraid taking the foam off would just allow salt/brine mist to make it into the engine compartment and cause all sorts of trouble inside there.
    Mine is only a year old, but so far, no rust anywhere on the frame…
    Stoney Ranger and Trail Runnah like this.
  14. Feb 28, 2022 at 10:25 PM
    Mine is 3.5 years old (18’) and no corrosion. I live in the desert and they don’t use salt here.
    For now I am going to leave the foam.
    I just went out in the garage and took these pictures. It’s looks to me like the anchors are attached at the corner of the frame structure. I didn’t see how you could attach an anchor behind this area because the sway bar mounts are very close behind.
  15. Feb 28, 2022 at 11:10 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    I've used them for snatching and doubling winch line back through a snatch block and I think they're fine. Probably not the gold standard of recovery points but I've never had a failure, seen a failure, or heard of a failure. The 2 times in their life most people will use these, they'll hold up well.
  16. Mar 1, 2022 at 2:27 AM
    Matt83
    Matt83 New Member
    Northeast
    On a side note, the purpose of the foam is for what? Is it routing airflow?
  17. Mar 1, 2022 at 8:33 AM
    afret
    North Idaho
    The Apex recovery point looks great but the KDSS version looks to be a pain to install.
  18. Mar 1, 2022 at 8:38 AM
    afret
    North Idaho
  19. Mar 1, 2022 at 8:47 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Just use them. You’re silly if you spend $150-$300 on recovery points that are held on by 2 bolts because someone on a forum told you to be wary of using these points.
    they work fine.
    Slopemaster likes this.
  20. Mar 1, 2022 at 10:00 AM
    Oh, no KDSS on mine.
  21. Mar 1, 2022 at 10:13 AM
    K-Paul
    Corbin Dallas
    SR5 4WD
    You hit the nail on the head. The purpose was for a few times use across the life of the vehicle. Not for repeated snatching in the boondocks.
    I've heard people say they use them all the time for off-roading. Although clearly our rigs are capable, i'm sure Toyota R&D is not factoring in the off-road community when designing these tie down points. Hence why they are called "Tow-Down Points". Not "Recovery Points".
    Clearly if you off-road the preference is to get appropriate recovery points. Don't have them? Its not a sin to use them..
    semprenissart and Slopemaster like this.
  22. Mar 9, 2022 at 1:45 PM
    WestcoastMark
    WestcoastMark New Member
    19 ORP with KDSS
    As a new owner of a T4R, I promptly got mine stuck in soft snow in Utah. We used a bridled chain set up to get myself pulled out. We did pull it out as straight as possible, but it worked fine. Prior to the chain set up, we tried it with some shady straps... and the straps failed before rings.
    MeefZah[QUOTED] likes this.
  23. Mar 9, 2022 at 4:20 PM
    Zal4R
    Zal4R New Member
    ‘21 LR TRD Pro
    Eibach TRD Pro Springs RCI Skids
    So, saw a Tacoma use the 2 factory tie downs and a loop around the frame to get winched (3 winches at the same time) out of a wash. So, I think they will be fine for anything I can think of, since it’s the same frame and such. Would I use them to get dragged up a rock ledge sliding completely on the skids/frame, probably not, but I am not going to be in that situation.
    Stoney Ranger likes this.
