Quick Links: Engine is way louder than it used to be. It sounds the same but just amplified... Third GEN water temperature gage Aftermarket Radio Install Connector Problem Any third genners running aftermarket headlight housings? Computer codes and check engine light Replacing differential oil and correct oil to use
Factory and aftermarket Wheel studs
Discussion in '3rd Gen 4Runners (1996-2002)' started by Oppie878, Dec 11, 2023.
