Extended brake lines/Lift
Discussion in '3rd Gen 4Runners (1996-2002)' started by 2000T4R, Apr 21, 2021.
  1. Apr 21, 2021 at 1:21 AM
    2000T4R
    2000T4R [OP] New Member
    Hi my first post I’ve been wondering what extended brake line would be best for my 3rd gen along with if I should do the toytec aluma suspension kit so it would come with diff drop and durobump stops then I’d do a camburg uca or if I should do SS current 1.2 lift with 2.5 shocks since I’m going to be doing a bumper, skidplate and rock sliders along with the camburg uca
  2. Apr 21, 2021 at 8:14 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Not necessary at all, as the rear sway bar limits your total droop.
    Also, a diff drop is absolutely useless.
    If you are going to exceed 2" in lift over stock height, I recommend getting high angle CV axle boots.
  3. Apr 21, 2021 at 9:23 AM
    2000T4R
    Would you recommend the SS current 1.2 kit or toytec aluma ?
  4. Apr 21, 2021 at 12:36 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Sorry I can't answer that as I only have experience with Fox 2.5 and King 2.5; currently running King 2.5's front and rear.
  5. Apr 22, 2021 at 4:22 PM
    2000T4R
    I think I’m going to go with the radflo stage 2 lift and I think it should be good ?
