Exhaust Manifold write up or info?
Discussion in '5th Gen 4Runners (2010-2024)' started by Checook, Apr 14, 2019.
  1. Apr 14, 2019 at 1:29 PM
    Checook
    Checook [OP] New Member
    Che
    15 4runner SR5 4x4 Silver
    I have a 2015 SR5 with an exhaust leak on the driver side. I have isolated the sound to the manifold and it all but disappears at temp. I verified it is not the solenoid thing on the intake manifold. I did quite a bit of searching for write ups or info on swapping an exhaust manifold and couldn't even come up with a photo. Any input or even someone who had the stealership do the work that could give me an idea of what it cost? I would rather do the work myself to save money but would like an idea of what I would be getting myself into.
  2. Apr 14, 2019 at 4:02 PM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    not what I ever heard . when an exhaust manifold leaks the bolts snap off then the leak ..
    post vehicles history . you original owner .. engine had work done ..
    a engine with 150K miles and 10 plus yrs old the manifold bolts do break some times
  3. Apr 14, 2019 at 4:17 PM
    Checook
    Che
    Third owner, just around 56,000 miles. It is in really good shape otherwise. I have been all over working on her without finding any surprises or signs of abuse. It started out in Massachusetts and the exhaust in front of the muffler does show some pretty good rust..... but only the exhaust and not the body anywhere. The engine block has the white scale corrosion to a small degree all over.
  4. Apr 15, 2019 at 5:56 AM
    j cat
    j cat New Member
    massachusetts
    since low miles and only 5yrs old could be some other issue not the manifold . use a 3/8 rubber hose stick one end in your ear and the other to probe the noise location.
    could be engine internal noise.. I have had a problem on GM engines the ex man creates a ticking sound then I found the bolt head popped off .. could be lifter noise on cold starts .. add 4OZ of marvel mystery oil to the engine oil .. if the noise goes away then the oil servicing is not properly done [sludge] .. 0-20wt synthetic .
  5. Apr 15, 2019 at 10:35 AM
    Checook
    Che
    I did an oil change myself around a thousand miles ago. Ran seafoam for 200 miles prior, 0-20 mobile1 extended life and motorkote. I do really need to remove the shield to tube check like you said to isolate further. Been super busy with work, visiting family and kids birthday. Thanks for the input.
  6. Apr 15, 2019 at 10:48 AM
    Benny123
    Benny123 Toyota enthusiast
    Southeast Charlotte, NC
    2016 Nautical Blue SR5 Premium
    LEDs all around, otherwise bone stock.
    Yeah, look closely to try to find the noise. I did see a video with JB Weld that Chrisfix did to find & seal an exhaust leak to so you may not have to do an entire manifold replacement if the leak is small. It certainly would be odd having a leak at such low mileage.
    Update: here you go.
    Also of note there is something called the "Toyota tick" that is fairly common and is also normal. Lots of threads on that, which I'm sure you can find.
