Exhaust leak into cabin
Discussion in '5th Gen 4Runners (2010-2024)' started by DrewF, Dec 17, 2024.
  1. Dec 17, 2024 at 1:34 PM
    DrewF
    DrewF [OP] New Member
    2014 4Runner limited
    My exhaust pipe rusted apart on my 2014 Limited causing the exhaust to melt rubber floor plug, carpet backing, and styrofoam under carpet. Has this happened to anyone else? Also, I need to replace the melted styrofoam and insulation underneath with something less expensive and that will cover that electrical connection. Any ideas?
  2. Dec 17, 2024 at 1:39 PM
    Never seen that before. Sorry to hear man but glad you are ok.
    DrewF[OP] likes this.
  3. Dec 17, 2024 at 1:57 PM
    I'd just fix the pipe, plug the hole and keep driving.
    I wouldn't do anything with the foam.
  4. Dec 17, 2024 at 3:16 PM
    Common to see the exhaust fail there around that age.
    Use the silver foil Noico adhesive insulation. Popular in the stereo installation circles (sound deadening) and off road circles (easier cleanup when swamped).
    DrewF[QUOTED][OP] likes this.
  5. Dec 17, 2024 at 6:24 PM
    Wow, that’s a weird failure. Especially since there’s hardly any corrosion around that exhaust break.
  6. Dec 18, 2024 at 1:16 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    This... and move on.
  7. Dec 18, 2024 at 1:08 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    That leak must have been going on for a while. I would cover the missing foam with some sound deadening/proofing and put it back together. The kind used for car stereos. Thicker the better.
  8. Dec 18, 2024 at 7:26 PM
    DrewF
    It happened during an 11 hour road trip with cargo area loaded down. Any suggestions on what to cover that little electrical connection with? Curious how it was covered before, by styrofoam? Never felt it while crawling around back there.
  9. Dec 18, 2024 at 7:33 PM
    Do you mean that black rectangle where the styrofoam melted away? If so, I bet that the styrofoam had a relief pocket molded into it to go over it.
  10. Dec 19, 2024 at 8:49 AM
    Rocko9999
    2011 Limited
    I would cover it with a section of plastic-grocery bag, ziplock, then go over it with the sound proofing or jutting material. It's inside and not critical as far as protection is needed.
  11. Dec 20, 2024 at 8:21 AM
    Rocko9999
    2011 Limited
    I would also remove all burnt sections. Do they stink? That burnt smell can sometimes permeate later into the cab.
  12. Dec 20, 2024 at 8:54 AM
    DrewF
    We smelled something during our drive home, but couldn't figure out what it was. Luckily, I rolled my window periodically, when I got tired.
  13. Dec 20, 2024 at 10:05 AM
    Rocko9999
    2011 Limited
    I would cut out the damaged area. That burnt smell can last for years.
    McSpazatron likes this.
  14. Dec 20, 2024 at 10:58 AM
    That’s actually a bit scary. I had a CO poisoning experience myself. I realized what was happening before things got real bad, but it’s very easy to not notice. It’s sneaky, and it doesn’t always smell while it’s happening.
    Have you had the chance to look at the break in the exhaust carefully? Did it actually rust through, or fracture? It just seems like a very odd break.
  15. Dec 21, 2024 at 1:02 PM
    chedd7
    chedd7 New Member
    Saturday
    Agreed, there isn’t much difference with or without the foam IMO
