Ever swapped out a 2004 V6 motor to a 2008 V6? What did you have to change
Discussion in '4th Gen 4Runners (2003-2009)' started by DxD25, Jul 13, 2024.
  1. Jul 13, 2024 at 9:48 AM
    DxD25
    DxD25 [OP] New Member
    Dave
    2004 Toyota 4 Runner V6
    Has anyone ever swapped out a 2004 Toyota 4Runner V6 motor to a 2008 V6 motor? If yes what did you have to change to get it to work
  2. Jul 13, 2024 at 9:51 AM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    2006 and 2008 should be the exact same motor for the V6. You shouldn't have to change anything except parts that need replaced due to wear and tear.
  3. Jul 13, 2024 at 10:10 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    He said 2004 V6 with a 2008 V6, any difference there?
    Bob likes this.
  4. Jul 13, 2024 at 10:35 AM
    xtremewlr
    Todd
    Tucson, AZ
    I could have sworn he said 2006. My bad.
    2004 will have single VVT-I where the 2008 will be dual VVT-I. The cam sensor wires will be 2 for 2004 and 3 for 2008.
    So yes, you would need to change some additional things to get the later model 1GR motor working in a 2004 4Runner.
    I found this thread which will give you more information - https://www.4runners.com/threads/1g...range-and-what-to-expect-when-swapping.36780/
    Bob and AuSeeker[QUOTED] like this.
  5. Jul 13, 2024 at 11:25 AM
    BassAckwards
    BassAckwards New Member
    2006 4Runner V6 SR5
    All 4th gen 1GR v6’s are single VVTI. Only the v8 had a change from single to dual VVTI.
    5th gen’s with the 1GR are dual VVTI.
    xtremewlr[QUOTED] likes this.
  6. Jul 13, 2024 at 12:10 PM
    xtremewlr
    Todd
    Tucson, AZ
    Good to know. I was only regurgitating what was posted in that link I provided.
    The V8 for 2003-2004, for the 4runner at least, was non-vvit. 2005 to 2009 are single vvti I beleive.
  7. Jul 13, 2024 at 12:12 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    2010 Zombie Truck
    Please see signature!
    Didn’t older 4.0L engines have a timing belt and newer ones have a timing chain?
  8. Jul 13, 2024 at 12:30 PM
    scottiezilla
    scottiezilla New Member
    This I read to be the case a few weeks ago
  9. Jul 13, 2024 at 12:42 PM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    I'm pretty sure if I'm not mistaken the 3rd Gen V6s had a timing belt, 4th Gen V6s and after had a timing chain.
  10. Jul 13, 2024 at 3:35 PM
    xtremewlr
    Todd
    Tucson, AZ
    The 1GR-FE 4.0L V6 used in the 4th gen 4Runners from 2003 to 2009 are all timing chain motors. This motor was also used in the 2nd gen Tacomas starting in 2005.
    The older 5VZ-FE 3.4L V6 in the 3rd gen 4Runners and 1st gen Tacomas was a timing belt.
  11. Jul 13, 2024 at 4:22 PM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    Generally speaking, if you change out an engine that is compatible, you need to install the engine sensors and actuators that are consistent with the original engine and original ECM.
