Entune 3.0 jbl head unit with older jbl amp?
Discussion in '5th Gen 4Runners (2010-2024)' started by Chsen, Sep 5, 2024.
  1. Sep 5, 2024 at 7:28 PM
    Chsen
    Chsen [OP] New Member
    2015 Toyota 4runner Limited Red
    Has anyone used the latest jbl head unit with CarPlay from 2020+ with older 2015 jbl amplifier?
    situation: I have got my latest head unit, but don’t have an amp yet. I have to try out the head unit to make sure it works as I have purchased it from
    Ebay. Want to make sure if i try the head unit out, it doesn’t destroy anything.
    could anyone share inputs?
  2. Sep 5, 2024 at 7:34 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    To use the JBL head unit, you will have to purchase the JBL factory amp also to make it work. Also, the wiring harness costs over $600 to make the whole thing work.
    If your car already has JBL, you would still need to get the new JBL amp.
    In short, if you can return it, return it and get a non JBL unit. That is plug and play and the harness runs about $200.
    If your car already had JBL, you are out of luck.
  3. Sep 5, 2024 at 8:28 PM
    Chsen
    My question is a little different. I am getting a latest jbl amp in mail. But I need to test the latest jbl head unit asap that I already received. I do have the adapter aswell. Hence asking if I plugin the latest jbl head unit with the adapter, will it affect my speaker system?
  4. Sep 5, 2024 at 8:29 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    From what I understand the latest JBL headunit ( 2020+) will not work unless the JBL amp is also hooked.
  5. Sep 14, 2024 at 10:00 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Correct speaker ohms are what kill you on the JBL
  6. Sep 14, 2024 at 3:21 PM
    TheSponge
    TheSponge New Member
    What did you pay for the stereo?
  7. Sep 14, 2024 at 5:57 PM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Does the Entune come with subwoofer? Mine does does this thing called CDs. Whatever they are. I discovered that.
