Entry Level Suspension
Discussion in 'Suspension' started by chrispy4runner, Mar 22, 2024.
  1. Mar 22, 2024 at 5:30 PM
    chrispy4runner
    chrispy4runner [OP] New Member
    Hey guys. Im new to the suspension game. I have my 2018 TRD Offroad with 70k miles on it and im looking to upgrade to a new suspension. Ive been doing as much research and watching as many videos on it as possible and my top 3 choices are Eibach stage 2r, Icon stage 1, and Bilstein 6112 with 5160 + icon springs in the rear.
    my intent is to lift the front about 2-2.5 inches and the rear 2 inches while going off roading every now and then and also up to the slopes for snowboarding in the winter.
    Ive been hearing people say the best bang for the buck is the 6112 and the 5160 set up but why is that? Have you tried the Icon stage 1 and compared it with the rest because I see a few negative thoughts about them from people. Not really sure why? They dont provide the "why" when they say negative things about them.
    Thanks!
    djwantke likes this.
  2. Mar 22, 2024 at 5:49 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey @chrispy4runner
    Welcome here, and great name!
    Bilstein really is a great bang for your buck, with long track record, regardless of some who dislike Bilstein (they usually have better setups).
    I run 5100's on all four corners, 3" OME lift springs in front, 2" ICON lift springs in rear. For my use, I really enjoy this setup from these three brands. I knew virtually nothing I know now when I did the upgrade, I would 100% pay a little extra for 5160/6112 and the improved performance they bring.
    Goodluck
    TrailSpecial22, kevinRR and 2Toys like this.
  3. Mar 22, 2024 at 6:20 PM
    chrispy4runner
    Hey thanks for your input! I meant people tend to talk negatively about the Icons not the Bilsteins.
    and around how much would the whole set up be for the 6112 ome and the 5160 with the icon springs?
    Also Ive heard you need to rebuild the Icons after every so many miles.
    Is that the case with the bilsteins as well?
  4. Mar 22, 2024 at 6:49 PM
    Right, so I only have Icon springs and none of their struts. The rear coils are dope.
    I don't think Bilsteins can be rebuilt.
    They last as long as other many other shocks, I think ppl say <100k miles
    Someone else can tell you the cost from their experience
  5. Mar 23, 2024 at 5:20 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    @djwantke
    I'm interested in getting the 2" Icon rear springs for mine. Do you know your rear measurement from wheel fender to center of hub? I'm trying to figure out if it would cause too much rake or be about just right. I'm at a fairly level stance right now with about 130 lbs. of deckbox with gear. Thx!
  6. Mar 23, 2024 at 5:43 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    IMG_3069.jpg The topic of “entry level” suspension will draw lots and lots of opinions and generally, what people have is what they comment on. I fall into that group!
    I have Bilstein 5100’s on my 2021 TRD OR along with Dobinsons 302 front and 599 rear springs and JBA upper control arms.
    This setup gives me right at a 2” lift all around while supporting the weight of RCI aluminum skids (incl gas tank skid), sliders and hybrid steel bumper and winch. The lift is from the springs as the front 5100’s are set at OEM height.
    This “budget” suspension cost me approximately $1500 with me doing the install.
    The ride is fairly firm on the highway greatly reducing the nose dive and side to side wallowing you get from the OEM setup. I did about 600 miles of off pavement on the Wyoming BDR last summer and the setup handled great.
    Maybe the only complaint I can share is that the Bilstein 5100’s being digressive shocks do take small bumps harder than some of the more compliant, higher end shocks. That said, I’m still very happy with how they ride.
    My rig sees 95% use on pavement so this setup provides me with great pavement handling along with good to very good off pavement handling at a good price point. Also, I’m running BFG K02’s in 265-70-17 on the stock OR rims…
    I was able to register for the Rocky Mountain Toyota Roundup in Ouray Colorado for July 2024 and this is the setup I will be running for all the trails there…
    Let us know what you choose…
    Cheers,
    Bob
  7. Mar 23, 2024 at 6:28 AM
    Higgbra73
    Higgbra73 Nitrous Fixes Everything
    Brad
    Chicago
    16' SR5 Premium 4WD
    Voxx "PRO's" Bronze (17x8.5) wrapped in 285/70-17 Mickey Thompson Baja Boss A/T's, 5100's with Dobinsons C59-302 2.5" front coils and Ironman 1.5" Light Load rear coils. RCI Engine Skid plate. CAT Shield SS. Freedom Offroad UCA's. 14" Borla Pro XS Muffler (40358)
    I also use 5100’s and Dobinsons 302 front springs and Ironman Rear springs (couldn’t pass up holiday deal) giving me 2.5 upfront and 1.5 in the rear. Since mine is mostly 80% street/road driven, I drive mine daily at work which is unkempt mix of potted asphalt, rocks and dirt at slow speeds. The why of it is cost & put them on and forget. Zero maint for 60-100k mi.
  8. Mar 23, 2024 at 9:57 AM
    Hey man, yeah for sure happy to help here's my measurements after normal amount of spring settling:
    Also, some rake is good, and needed, as opposed to perfectly level doesn't and rear. Because when you load up people, gear, and/or tow something, that back end is sagging and front tilting up. Keep in mind, the 4R lines are deceiving, the fenders naturally sit at different heights on the body, as well as from the ground. So the truck frame is level even when the fender to tire gap is larger I'm the rear.
    On a heavy Camping trip this summer my rear end icons compressed 1" fyi. Was cool to see.
    FD: 22"
    FP: 22-1/4"
    RD: 23-1/2"
    RP: 23-3/4"
    normal rake
    weighted rake
    ^fender height off ground also
  9. Mar 23, 2024 at 10:30 AM
    Okay bro, so for pricing
    Heres the shop invoice in $CAD in 2021
    See the 5100 pricing and add xx% for 5160/6112
    Labour is listed as well, I did not install lift myself
    front ARB/OME 2884 springs 590lb spring rate $271.15/pair
    front 5100's $356.40/pair
    labor: $244.00
    rear 2" ICON 158506 springs 700lb spring rate $301.99/pair
    rear 5100's $267.30/pair
    labor: $244.00
    Alignment $122.00
    TOTAL: $1,806.84 +tax(approx 12% here = $216)
    Just over 2k all in
  10. Mar 23, 2024 at 2:41 PM
    chrispy4runner
    Hey did you need an upper control arm for your lift?
    im looking at 2.5 lift and some guys tell me I would still need it for that lift and some guys tell me that I can get away not needing one.
    I just got a quote with the upper control arm plus installation an extra 1000...
  11. Mar 23, 2024 at 3:00 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Problem is, you don't really know until you try, which is why you get different answers depending on who you ask. Each 4runner is different and you may or may not get lucky. I bought UCAs when I got new shocks and coils just to be safe because I didn't want to pay for a 2nd installation.
    I think someone may have mentioned Dobinsons in an earlier post - that's what I have and absolutely love them. I went with IMS shocks, which are slightly more expensive, but I've heard good things about their base shocks as well and think I would have been fine with those
  12. Mar 23, 2024 at 5:57 PM
    Yeah I paid $1094.49 CAD in '21 for UCA's.
    *edit: plus tax o_O
    I recommend them if you run 285/70 or larger size tires
    Positives:
    Robust
    Adjustability
  13. Mar 23, 2024 at 6:56 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Out of the setups you listed. I go with 6112/5160. The 6112 are larger and the valving is excellent. Theres plenty of quality reviews on them. From what I remember they also offer more suspension travel then the eibachs(not sure about icons).
    If your lifting over 2"(in the front) id sugguest aftermarket uca.
  14. Mar 24, 2024 at 2:58 PM
    TrailSpecial22 New Member
    PA
    6112/5160 get my vote!!
