Engine won’t start when engine warm!!
Discussion in 'General 4Runner Talk' started by Tremblay85, Apr 7, 2018.
  1. Apr 7, 2018 at 7:58 PM
    Tremblay85
    Tremblay85 [OP] New Member
    Matthew
    1996 Toyota 4 Runner
    Engine starts fine when cold, When the engine is warmed up and you shut it off for about 10 minutes it will not start back up until it cools back down I replace the coolant temperature sensor crankshaft sensor in the coils and plugs also cleaned the mass airflow sensor , And also cleaned out the Throttlebody with some Cleaner Any suggestions would be very helpful
  2. Apr 10, 2018 at 8:52 AM
    Caltech90
    Caltech90 New Member
    '19 TRD OR
    Does is turn over?
  3. Apr 10, 2018 at 9:28 AM
    SnowroxKT
    SnowroxKT New Member
    Alaska
    2018 T4R TRD Offroad
    2018 T4R Offroad SAS 1995 Tacoma
    On my Tacoma there were 2 coolant temp sensors. One did the gauge, one went to the ECU. Are you sure you changed the correct one?
