Engine turns but won't fire
Discussion in '2nd Gen 4Runners (1990-1995)' started by hillbillyoffroad, Jun 11, 2020.
  1. Jun 11, 2020 at 1:00 PM
    hillbillyoffroad
    hillbillyoffroad [OP] New Member
    dex
    94 grn 4 runner 2nd gen
    i have a 94 runner, i have fuel all the way to injectors. engine turns but wont fire!! when i spray carb cleaner into intake, it def wants to start!! any help or suggestions would be greatly appreciated> tia dex,, iv checked, relays,fuses ,fuel pump,filter etc.
  2. Jun 11, 2020 at 1:30 PM
    You sure the fuel just doesn't suck?
  3. Jun 11, 2020 at 3:32 PM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    Can you smell fuel? Injectors spewing like they should?
    hillbillyoffroad[OP] likes this.
  4. Jun 12, 2020 at 12:35 PM
    hillbillyoffroad
    dex
    yes! have fuel to the injectors
  5. Jun 12, 2020 at 1:07 PM
    bthp223
    bthp223 New Member
    Nevada
    1990 4X4
    Maybe check-replace the frame mounted fuel filter ? Could be clogged keeping the pressure down.
  6. Jun 12, 2020 at 1:26 PM
    hillbillyoffroad
    dex
  7. Jun 12, 2020 at 1:29 PM
    hillbillyoffroad
    dex
    my drive shaft busted, fixxed it! it was starting just fine prior to! it bust one line which was also fixxed, but now it wont fire! could it be possible it jumped timing when drive shaft busted??
  8. Jun 12, 2020 at 1:37 PM
    bthp223
    bthp223 New Member
    Nevada
    1990 4X4
    I can only help saying go back to the basics, Air, Fuel, Fire. Start there and eliminate each one ya know.
    Verify spark, check cap, rotor, wires, proper plug gap. Check Fuel, pressure, maybe pull the cover and check your belt, timing marks. Gotta be something basic, hopefully.
    BestGen likes this.
  9. Jun 18, 2020 at 5:58 AM
    Fourtoad
    Fourtoad Gatorgrl's Yotas
    Gatorgrl
    SWFL
    1991 V6 5 speed super clean, Black and grey
    Stock with headers and after market wheels.
    Circuit opening relay possibly.
  10. Jun 18, 2020 at 6:05 AM
    Benny123
    Benny123 Toyota enthusiast
    Southeast Charlotte, NC
    2016 Nautical Blue SR5 Premium
    LEDs all around, otherwise bone stock.
    Check your grounds and battery cables make sure no corrosion there. And, of course, battery replacement if its been over 5 years. Check alt.
    Fourtoad likes this.
  11. Jul 2, 2020 at 1:44 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    The AFM has a switch in it that tells the fuel pump to run as soon as the engine is turning over and drawing in air. If that switch is broken in the AFM you wont get any fuel pressure. Or if one of the intake pipes is disconnected or cracked and provides a huge air leak between the AFM and the TB then the flapper in the AFM will not move enough to trigger switch and again no fuel pressure.
    Fermin4 and Fourtoad like this.
  12. Aug 16, 2020 at 6:35 PM
    Fermin4
    Fermin4 New Member
    Adams
    1995 2WD 4Runner 3VZ-E Engine OBD-1
    None
    I just check the COR relay myself yesterday and I tale my hat off to everyone could can put them back. What w Job!!!
    My 3VZ-E some times start other does not checked everything and runs missing a lot from about 1300 to 2000RPM. after that seems to smooth a little. Any clues?
