Engine swap in 2004 4runner
Discussion in '4th Gen 4Runners (2003-2009)' started by delphi444, Jan 31, 2023.
  1. Jan 31, 2023 at 1:25 PM
    delphi444
    delphi444 [OP] New Member
    Hi Folks,
    I've got a 2004 4WD 4runner, 4.0L V6. Will a 2WD 4.0L V6 engine be compatible? And allow 4WD to still work? Or should I try and find a used 4WD engine.
  2. Jan 31, 2023 at 4:25 PM
    delz05
    delz05 New Member
    2006 4Runner LTD
    Just beginning!
    The engines have nothing to do with 2WD and 4WD... just stay with the 4.0L V6, try to obtain a "later run" (06-09) to avoid the head gasket issues.
    wdsteven likes this.
  3. Jan 31, 2023 at 5:35 PM
    wdsteven
    wdsteven New Member
    There will be very Minor Difference in a couple of Vacuum lines with the 06 to 09 engines but just look at your original setup and plug off the ones that you do not need.
