Engine Oil Question
Discussion in 'General 4Runner Talk' started by 4onto, Apr 1, 2025 at 5:34 AM.
  1. Apr 1, 2025 at 5:34 AM
    4onto
    4onto [OP] New Member
    Toronto
    2009 SR5 V6 4WD
    What's the best oil to use in my 4Runner? Most of my driving is at night. Thanks.
  2. Apr 1, 2025 at 5:45 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Canola. Smells like french fries. JK.
    Literally anything that meets factory recommendations. There are a ton of oil debate threads here. Use google to find these threads since this site's search function is... Well it's there.. works sometimes.
    Toy4X4, icebear and 4onto[OP] like this.
  3. Apr 1, 2025 at 7:02 AM
    I personally only add Penzoil Ultra Platinum. But as mentioned above any oil brand that meets factory recommendations is fine. I also only use OEM oil filters because they're cheap and do a great job.
  4. Apr 1, 2025 at 7:55 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Depends if you change oil yourself or have a Toyota dealer do it.
    Lately I am having my dealer change and I specify Toyota bottle oil. Costs are comparable.The bulk oil dealers use may or may not be as good.
    If its an independent shop (or DIY) I provide the oil and filter,its full synthetic 5 qt. Jugs from Walmart plus a couple single quarts.
    I usually select Mobile 1 full syn, There is also Pennsoil, Valvoline and others.
    4onto[OP] likes this.
  5. Apr 1, 2025 at 8:04 AM
    Owners manual have the correct answer.
    Updated -
    Just noticed OPs 4Runner is 2009
  6. Apr 1, 2025 at 8:37 AM
    Any off the shelf brand of the correct viscosity that tickles your no no zone.
    TrailSpecial22 and 4onto[OP] like this.
  7. Apr 1, 2025 at 9:33 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Well, if at night then........
    TrailSpecial22, 3JOH22A and 4onto[OP] like this.
  8. Apr 1, 2025 at 9:49 AM
    2016Pro
    Get the red, easier to see at night
    3JOH22A and 4onto[QUOTED][OP] like this.
  9. Apr 1, 2025 at 10:30 AM
    4onto
    Toronto
    2009 SR5 V6 4WD
    My friend's brother-in-law said 0W-20 is better for night driving, especially for 2009-older 4Runners. Any thoughts?
  10. Apr 1, 2025 at 10:35 AM
    1SilverRunner
    Tejas
    Alright. I can't tell if this is a troll post. I give up.
    Use Canola oil. Its the best late night oil. Don't use it during the day though. Swap out to something more heart friendly. I prefer Avocado oil for those day trips, it can stand up to the high heat. Then back to Canola for late night.
    I change the oil every evening. No filter replacements ever. Oils always clean
  11. Apr 1, 2025 at 10:39 AM
    7Runner
    7Runner Forum Loiterer
    2018 Silver SR5P
    Paraffin lamp oil seams to be the most logical choice.
    Won't even have to use your headlights.
  12. Apr 1, 2025 at 11:00 AM
    1SilverRunner
    Tejas
    If you do settle on Olive oil (which is a great choice) just be sure to use extra virgin at night, but regular during the day.
    Also, be sure it's cold pressed and sustainably sourced. Very important to not skip over the details.
  13. Apr 1, 2025 at 11:11 AM
    Your engine doesn’t see night or day. It just wants the recommended viscosity and regular changes to be happy.
    Toy4X4, icebear and 4onto[QUOTED][OP] like this.
  14. Apr 1, 2025 at 11:15 AM
    1SilverRunner
    Tejas
    https://www.4runners.com/threads/what-engine-oil-weight-brand-do-you-run.29281/
    https://www.4runners.com/threads/oil-viscosity.26613/
    https://www.4runners.com/threads/cant-decide-between-toyota-oil-and-pennzoil.33801/
    I feel the need to apologize for my assholery. There are just so many oil threads already so these typically get a little funny.
    Toyota Genuine Motor Oil (TGMO) is Mobil 1 with an additive package spec'd by Toyota. Many users swear by it.
    Depending on your climate you may find it beneficial to move to a different weight of oil though.
    Pennzoil Ultra Platinum is another good option with a lot of detergents, which helps keep everything clean. Choose the weight based off of your use and climate. Living in Toronto I don't imagine you'll need to change weight. TGMO and Toyota OEM filters will keep the engine healthy for a very long time. (Beware of counterfeit filters on scamazon or ebay. Just buy them from a dealer)
    RumHamRunner73 and 4onto[OP] like this.
  15. Apr 1, 2025 at 11:25 AM
    FatChance
    Sedona
    2024 4Runner Limited
    Happy April Fools Day!
  16. Apr 1, 2025 at 11:33 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I start my 4R up every day but never leave the driveway, what’s the best oil should I use????
  17. Apr 1, 2025 at 11:36 AM
    2016Pro
    The most expensive you can find and change every 100 miles it's cheap insurance
  18. Apr 1, 2025 at 11:38 AM
    2ndGen22re
    CR
    Carson Valley, NV
    I try to keep the miles off it, that’s why it stays in the driveway….lol
  19. Apr 1, 2025 at 11:40 AM
    Photon_Chaser 52,536 and counting…
    Up, down and all around!
    Every hundred miles? Do it by marine standards, every hundred hours!
    4onto[OP] and whippersnapper02 like this.
  20. Apr 1, 2025 at 11:50 AM
    4onto
    Toronto
    2009 SR5 V6 4WD
    Times two!
  21. Apr 1, 2025 at 12:26 PM
    lol, yeah i wondered too why that was relevant to add to the post......I usually drive at night
  22. Apr 1, 2025 at 12:30 PM
    "Mobil 1 with an additive package spec'd by Toyota. Many users swear by it." My neighbor has 520k miles on his 2004 4Runner, he uses the cheapest oil and the cheapest filter.
    And yes, I enjoyed your post because there are no less than 1,000 threads on this topic.
  23. Apr 1, 2025 at 12:42 PM
    1SilverRunner
    Tejas
    Yeah honestly change interval makes a bigger difference than brand. We all have our biases.
    If it meets the oe recommendation its good to go. Same for filters.
    Now back to it. What's the best oil to use for night driving?
  24. Apr 1, 2025 at 1:02 PM
    I know it's an April Fools thread, but 0W20 should not be used in OP's 2009 at night. 20-weight oil is too thin in the version-one 1GR-FE.
    TrailSpecial22, icebear and 4onto[OP] like this.
  25. Apr 1, 2025 at 1:13 PM
    Oh shoot...
    Just corrected my response to 5W-30 per 2009 owners manual.
  26. Apr 1, 2025 at 1:18 PM
    Speaking of April fools threads , I posted this on another group.
    Hopefully this would keep me safe in case someone try to sue me -
  27. Apr 1, 2025 at 1:25 PM
    4onto
    Toronto
    2009 SR5 V6 4WD
    A Lexus-badged BMW? Now THAT'S funny. (And unnerving at the same time.)
  28. Apr 1, 2025 at 1:34 PM
    New posts should be locked on April 1st to prevent lame shit.
    2016Pro likes this.
  29. Apr 1, 2025 at 1:39 PM
    Hungryhawk
    Southern CA
    2017 SR5
    I propose benefits to changing oil brands to get different additive packages. Same goes for fuel brands-different additive packages. The goal is to keep innards of engine and fuel system clean with no gunk.
    So I see no harm and possible benefits to change brands once in a while.
  30. Apr 1, 2025 at 6:00 PM
    is this a joke?
    4onto[QUOTED][OP] likes this.
