Engine Cleaning out of vehicle
Discussion in '3rd Gen 4Runners (1996-2002)' started by CoolToyota, May 16, 2024.
  1. May 16, 2024 at 10:25 AM
    CoolToyota
    CoolToyota [OP] New Member
    98 4Runner 1A5
    Wanting to pressure wash exterior of engine that is removed from vehicle - the headers and intake is removed - what is best way to seal up to wash it ? Could I take a piece of sheet metal - and rtv across the holes ? Reattach the valve covers same way w RTV just to cover some things up ? Thoughts
    The foil tape was just to keep dirt etc out for the moment
  2. May 16, 2024 at 2:58 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Was waiting on other replies here but since no one has chimed in I will
    I would reattach all covers. Tape everything else up. Use oven cleaner and rinse well.
  3. May 16, 2024 at 2:59 PM
    1SilverRunner
    Tejas
    Also to avoid flash rust of any cast iron components you can dilute your water with a rust inhibitor.
  4. May 16, 2024 at 4:04 PM
    CoolToyota
    98 4Runner 1A5
    Thanks for the input/advise all
  5. May 16, 2024 at 4:19 PM
    I would do this.
    I don't trust RTV to hold up against a pressure washer.
  6. May 28, 2024 at 7:29 PM
    CoolToyota
    98 4Runner 1A5
    Sound advice
