Engine Blown at 10k?
Discussion in '5th Gen 4Runners (2010-2024)' started by fsabe23, Oct 14, 2024 at 10:13 PM.
  1. Oct 14, 2024 at 10:13 PM
    fsabe23
    fsabe23 [OP] New Member
    Yesterday
    Does anyone know if the Tundra issues also affect the 5th-gen Four Runners? I just bought a brand new 2024 in May, and it just hit 10k, and my engine stalled. Then, when I tried to restart, it started smoking and wouldn't shut off, and then when it finally did, a bunch of smoke came out of my engine. Any thoughts?
  2. Oct 14, 2024 at 10:17 PM
    Tundra has a completely different engine. Have it towed to the dealership and go from there. I've not seen anything like this on a 5th gen.
  3. Oct 14, 2024 at 10:18 PM
    That’s a new one.
  4. Oct 14, 2024 at 10:44 PM
    icebear Recovered Kia Owner
    Tundra is completely unrelated, these are solid designs and construction but assuming no apparent cause, manufacturing defects can only be minimized and not eliminated.
    It’s warranty time.
  5. Oct 14, 2024 at 11:20 PM
    Oil leaked out? I mean mass production will have some issues no matter the brand but take it in for a warranty replacement.
  6. Oct 14, 2024 at 11:23 PM
    fsabe23
    Yesterday
    There are no visible oil leaks or fluid under the vehicle. In fact, I just had it in for the 10K free service, where they changed the oil. I drove it home with no issues after service, but this was the first time since I tried driving it. I bought this due to reliability issues so its a real bummer Im having major issue at only 10k brand new.
  7. Oct 14, 2024 at 11:26 PM
    Sounds like they messed up. Again take it in and any brand can have an unexpected catastrophic failure, even Toyota.
  8. Oct 15, 2024 at 1:14 AM
    Good chance the dealership botched something, or you just got a rare defect of some sort. As mentioned above, it's a warranty issue.
  9. Oct 15, 2024 at 3:31 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    I’d be on the phone with that dealership.
  10. Oct 15, 2024 at 4:45 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    There's your answer. Dealer service FAK'd something up if you had it there ,drove home & then tried to drive it after it sat since dealer work. They will have miles when they did the work, make sure you have your current mileage to compare. No Oil light on way home? I've heard of Toyota dealers (FJ Forum) releasing "serviced" vehicles W/no oil added. Check the dip stick before you try to start again. Take Pictures of everything Odometer, dip stick New oil hard to see on dip stick.
    2Toys and Thatbassguy like this.
  11. Oct 15, 2024 at 4:56 AM
    BettyWhite
    BettyWhite New Member
    Spice
    2024 4RnrSR5P
    Roof rack...for now
    Sounds like the mechanic forgot to put something back. Like everyone said...dealership mess. Keep us posted. Good luck
    LCJ77 and Thatbassguy like this.
  12. Oct 15, 2024 at 5:10 AM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    My money is on a dealership F up.
    LCJ77, Jennyjo14 and Thatbassguy like this.
  13. Oct 15, 2024 at 8:19 AM
    steelevo
    Utah
    From the symptoms and picture of the smoke location, could it be an electrical issue? Maybe rodent damage to the harness?
  14. Oct 15, 2024 at 8:33 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    This looks like they forgot to add oil back in. You managed to drive home with whatever little oil about a quart that stays inside the engine during an oil change.
    Once that was used, that's it. There has to be a low oil light on the dash though when you drove it home.
    Damn man, this sucks on any car let alone a 2024 one.
  15. Oct 15, 2024 at 8:35 AM
    Connor MacLeod
    Connor MacLeod New Member
    Connor
    2023 TRD Off Road
    This is why I never take my truck to the dealership (or any other shop if I can avoid it)...but especially the dealership.
    TN_FunRunner and Pavo like this.
  16. Oct 15, 2024 at 8:36 AM
    ThomasL
    ThomasL New Member
    Florida
    24 TRD Off Road Prem
    Damn bro, yeah shake down the dealer…
  17. Oct 15, 2024 at 8:38 AM
    mac1usa
    mac1usa New Member
    Yeah sounds like no oil or not enough oil was put back in after draining. Gosh that is a shame
    I would check to see if the oil pan bolt is in and secure; is there oil all over bottom of engine/skid plate area?
  18. Oct 15, 2024 at 8:51 AM
    Jennyjo14
    Jennyjo14 New Member
    Jennifer
    None
    This exact thing happened to my mother's 1984 Camry...with only 700 miles on it. Definitely a factory/dealership f-up. In her situation, it was shipped without an oil cap and no one bothered to look.
    This was back in the day when Toyota gave actual customer service. Her car was towed to the dealership, given a thorough checking, and within a week she was given a new car.
    Go to Toyota and raise some immortal hell, my friend. This never should have happened to you.
    LCJ77 and 2Toys like this.
  19. Oct 15, 2024 at 8:52 AM
    java
    java fauxrunner
    2023 ORP ice cap
    Should it not have seized? OP says the engine would not shut off. I bet an electrical issue.
    Source: Random guy on the internet.
  20. Oct 15, 2024 at 9:00 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Did you take it back to the dealer?
  21. Oct 15, 2024 at 9:05 AM
    fsabe23
    Yesterday
    I connected Blue Driver to pull codes, and this is what it says. I checked the oil, and it seems filled, so it doesn't seem like that now.
  22. Oct 15, 2024 at 9:06 AM
    Did you call the dealer or nah?
  23. Oct 15, 2024 at 9:14 AM
    fsabe23
    Yesterday
    I called dealer I bought it from and told them I serviced it somewhere else. I was afraid if I took it back to the one that did the original service they would try to cover up if they did something wrong.
  24. Oct 15, 2024 at 9:17 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Why are you asking the internet - which is full of expert fools? This is a pure and simple "take it back to the servicing dealer" issue. Only the dealer can determine if what went wrong was a warranty issue or a screw up during service and make good on it.
    Mr.DRZ, icebear and Rocko9999 like this.
  25. Oct 15, 2024 at 9:17 AM
    Rocko9999
    2011 Limited
    Well take it to a dealer. No need to self diagnose, it's under warranty.
  26. Oct 15, 2024 at 9:26 AM
    fsabe23
    Yesterday
    I'm having it towed to the dealer today. Just got off the phone with them. I posted the last nite when it first happened and was freaking out. Its brand new, and after I babied it over its first 10k, it started smoking so bad like it was about to blow up.
    Rocko9999[QUOTED] likes this.
  27. Oct 15, 2024 at 9:29 AM
    They can't deny a warranty claim unless something was done incorrectly by someone else that caused the damage. The other shop has insurance and would be liable to fix your vehicle if it was their fault. If it's an issue with rodents then your comprehensive insurance will cover it.
  28. Oct 15, 2024 at 9:36 AM
    fsabe23
    Yesterday
    I did have my front headlights, fog lights replaced with alpha rex and a front camera added. I am hoping they didn't screw something up in doing all that work electrically. I had zero issues when they did it all at 3k miles and drove it all the way across country after the work no issues. This issue only showed up right after my 10k service.
  29. Oct 15, 2024 at 9:39 AM
    Too Stroked
    Tom
    2021 SR5 Premium
    Who did the 10k service, another dealer or a private shop?
  30. Oct 15, 2024 at 9:45 AM
    fsabe23
    Yesterday
    Toyota Dealer ( Huntington Beach ) closer to where I live vs dealer I bought it from which is much further away.
