Engine/Battery Dies After Jump Removed???
Discussion in '4th Gen 4Runners (2003-2009)' started by ScottVee, Apr 17, 2023.
  1. Apr 17, 2023 at 2:56 PM
    ScottVee
    ScottVee [OP] New Member
    1997 Silver 4Runner Limited
    I have an '05 that has been stored for a couple of years +. I assume it needs a new battery. I have to travel to retrieve it, so I am wondering what else might cause the engine to kill when a jumper box is removed? I don't want to get there with a battery and have it kill. I really think it needs a new battery! Thank you!!
  2. Apr 17, 2023 at 3:11 PM
    Branden967
    Branden967 New Member
    6400' in CA
    2023 TRDOR Premium
    Kings Suspension SCS 17X9 -10 OS Ridge Grapplers If its chrome....black it out.
    Easiest thing to do is to buy a new battery. My guess is your alternator is probably dead if it will not stay running without a battery attached.
    Good luck, sounds like an adventure awaits.
    Ripper238 likes this.
  3. Apr 17, 2023 at 4:37 PM
    ScottVee
    That is a very good idea. I hadn't thought of that!! Thanks!!!
  4. Apr 17, 2023 at 5:39 PM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    I had an older 4 runner in the 90’s that had the same problem. It was the alternator.
  5. Apr 17, 2023 at 6:57 PM
    Stangheel
    Stangheel New Member
    Chris
    2021 Grey SR5
    Yes on the alternator.
  6. Apr 18, 2023 at 6:58 AM
    ScottVee
    Thank you all for you input! I greatly appreciate it!!!
  7. Apr 18, 2023 at 7:42 AM
    WNC2018Limited
    WNC2018Limited New Member
    I would also look over everything that's rubber on a vehicle that is that age and has been sitting for 2 years. Hoses could become excessively stiff and develop cracks. Tires can dry rot and develop tiny cracks. Even if they still have a lot of remaining tread, if they're over 7 or 8 years old they should probably be replaced. You can find the month and year of manufacture on the side of the tire. I'd probably also check the belts.
  8. Apr 18, 2023 at 7:57 AM
    ScottVee
    Great!! i had planned to replace the belts. I will inspect the tires also!! Thanks!!
    WNC2018Limited likes this.
  9. Apr 18, 2023 at 8:59 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    Maybe considering towing it home to work on some of these things. Borrow/rent a truck and a Uhaul trailer and get it home safely and then repair as needed. Tires and brakes should always be in tip top shape, IMO. I prematurely spend on tires and brakes all the time just to be safe.
  10. Apr 18, 2023 at 12:16 PM
    ScottVee
    Thank you!
  11. Apr 18, 2023 at 3:00 PM
    GreatWhitePig
    GreatWhitePig New Member
    Alternator is easy to test. When it’s working if you put a flat head to the screw holding the pully it will be magnetic. If it doesn’t catch the screwdriver it needs a new alternator.
  12. Apr 18, 2023 at 4:38 PM
    ScottVee
    Great reply!!! Thank you very much!!
