Electrical question for 88 4 runner
Discussion in '1st Gen 4Runners (1984-1989)' started by tkelley95, Aug 28, 2016.
  1. Aug 28, 2016 at 2:09 PM
    tkelley95
    tkelley95 [OP] New Member
    Tom
    1988 toyota 4 runner sr5
    I have an 88 4 runner. came up with an issue today...turn signals, emerg flashers stopped working as well as fan motor. thinking they may all be tied to the same fuse, but cannot locate the fuse box with this fuse. owners manual indicates there is a fuse box with 6 fuses behind the glove box but cannot locate it. there is a 10 amp and twenty amp fuse for the AC and heater. but no others. any ideas...looking for the 15 amp listed in the owners manual,
  2. Aug 31, 2016 at 9:52 AM
    codydoss
    codydoss New Member
    Cody
    Folsom, Louisiana
    1988 Toyota 4Runner SR5
    Restoration in progress. Donor 85 frame.
    I think the fuse box under the hood houses your turn signal fuse. I'm pretty sure it's the same fuse that runs your horn. The tail light fuse is in the driver side kick panel from what I can remember off hand. I'm not sure about the third box under the glove compartment. If I find out anything more, I'll be sure to let you know. Good luck.
