Eibach pro truck 2.75” springs with 5100s..Question
Discussion in '5th Gen 4Runners (2010-2024)' started by kwright8754, Apr 7, 2022.
  1. Apr 7, 2022 at 11:58 PM
    kwright8754
    kwright8754 [OP] New Member
    2018 trd ORP w/KDSS
    I was initially going to install 5100s on stock springs to achieve lift. I’m removing current spacer lift.
    However, I decided to buy eibach pro truck lift springs to pair. My question is, what setting should I set the 5100s to? I have an SSO slimline bumper installed and a prinsu rack on the way. No additional weight.
    Anybody know if these specific springs settle much? I have seen a mixed bag of info on this.
    Looking to Achieve 2.5” up front after settling and added weight. Would hate to tear it apart again to go up a notch on perch and don’t want to be above 2.75-3” max.
    E30-82-071-01-20 Eibach part #
  2. Apr 8, 2022 at 2:55 AM
    Foster1
    Foster1 New Member
    You could try to dm on Instagram if you have one. I think they're pretty responsive on there. Calling works too if you want.
    Why not just run the whole Eibach kit though? Comes with springs and shocks, and you could even buy them already assembled based on their advice. They'd have everything setup for you. Think they even have a sale going on right now.
  3. Apr 8, 2022 at 3:02 AM
    kwright8754
    2018 trd ORP w/KDSS
    Appreciate the reply. I decided to start a return on the 5100s with Amazon.
    Just purchased the Eibach adjustables on tire rack for $125 a piece. Says arriving on Monday.
    I already have a 1.5” spacer in the rear. Removing the current front spacer and installing the Eibachs.
    Now to figure out what perch. 1st or 2nd. So much conflicting info
  4. Apr 8, 2022 at 12:46 PM
    Foster1
    Foster1 New Member
    Probably first clip since you're trying to stay under 2.5" of lift. Recommend reaching out to Eibach, they do installs on 4runners all the time and have probably seen similar setups with the bumper and roofrack.
    What shocks are you planning to run in the rear?
  5. Apr 8, 2022 at 1:28 PM
    Mtbpsych
    Mtbpsych New Member
    Figure out what the spring rate is on those eibachs then go from there. You’ll mostly likely want a medium load sprint to achieve lift and support the added weight.
