Eibach Load Leveler
Discussion in 'Suspension' started by skillingsworth, Jun 14, 2024.
  1. Jun 14, 2024 at 8:03 AM
    skillingsworth
    skillingsworth [OP] New Member
    I am about to install the Eibach 2.0 on the front of my '22 ORP and I am going to go with the Eibach Load Leveler system in the rear with Bilstien 5100's. Question is on what springs to select. I have a Rigd Ultraswing with spare tire and a Gobi roof rack. I don't expect to add much more weight but am curious if I should go with the 0-200 or 200-400 springs. My use is 90% paved but I do get out in the mountains from time to time. I'm wanting a 2.5" - 3" lift overall. Am wondering if the 0-200 will be enough but don't want to stiffen the ride too much or sag with gear in the back. Opinions?
  2. Jun 14, 2024 at 10:07 AM
    LunarTR4
    LunarTR4 New Member
    22’ TR4 ORP LR
    Depending on what you're bringing with you for adventures will determine the springs. That being said, with the constant added weight of the two items you mentioned, I do not see why you would have issues with the 400-lb springs. I run the 200-lb springs empty 90% of the time and I think the rear rides just fine. Granted, I'm on stock rails and I do not have a tire carrier.
