Eaton e locker vs. ARB air locker
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Nov 25, 2023.
  1. Nov 25, 2023 at 1:31 AM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    I am contemplating over a front locker. The mod germ really got the better of me :)
    Which one is more reliable, e locker or air locker? Anyone here with a front locker?
    Harringbr99 likes this.
  2. Nov 25, 2023 at 5:46 AM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    It's on my long-term roadmap, especially when I get around to re-gearing. There are a lot of references on YouTube around this topic, but this is my favorite one, especially since these folks are 4Runner owners. They also have a lot of great information about the way our other off-road systems work. I'm leaning toward air locker for reasons they mention, but eLocker would be a lot easier to install I imagine.
    DBow14 and Yotaholic[OP] like this.
  3. Nov 25, 2023 at 9:32 PM
    Yotaholic
    Olympia, WA
    Wow nobody has a front locker installed here
  4. Nov 25, 2023 at 9:44 PM
    Most don’t need it. I have heard of air leaking issues with the ARB.
  5. Nov 25, 2023 at 11:17 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    I have ARB front and rear. My LE has no lockers off the lot, but since I re-geared to 4.88, adding lockers at the same time made sense.
    The trick with ARB is in the installation. I haven’t seen any issues with them that couldn’t be traced back to a botched install.
    Conclusion? Get a built 3rd member from a reputable company. I’ve first hand experience with ECGS and fully trust their work and have confidence in their commitment to make things right in the event of an issue. They do Toyota gears and ARB installs day in and out. With that kind of experience you get a higher degree of confidence in the work.
    So yes, ARB is a solid locker.
  6. Nov 25, 2023 at 11:29 PM
    Pavo
    Pavo New Member
    I actually had to use my air air locker in my Tacoma for the first time today (4Runner has the factory locker) I got the arb air locker two years ago, I would cycle it about once a month as recommended by arb and luckily it worked flawlessly, that being said I heard it can leak so if it does I’ll switch it to an Eaton electric locker
    Yotaholic[OP] likes this.
  7. Nov 25, 2023 at 11:30 PM
    Yotaholic
    Olympia, WA
    Is ECGS in WA?
  8. Nov 26, 2023 at 2:02 AM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    Louisburg, North Carolina
  9. Nov 26, 2023 at 7:53 AM
    GrimJeeper91
    GrimJeeper91 New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    I finally swapped in an ARB in the front of my Jeep (removed a limited slip). Needless to say the difference was night and day. I resisted for a long time because I too heard stories of air leaks. However, these seem to be attributed to installation problems. I had a reputable shop install mine and they used the heavy duty line three plus years ago and it's worked flawlessly since. I regret not having gone to an ARB much sooner! There's a YouTube video somewhere that compares the strength of various manufactures and ARB comes out on top.
  10. Nov 26, 2023 at 8:07 AM
    Oakboro, N.C
  11. Nov 26, 2023 at 9:53 AM
    I was thinking about Eton e-locker as it's a simple trouble free setup.
    Planning to do my own wiring. My plan is to power the elocker switch only when my after market front camera is on. So if;
    - front camera switch on + elocker switch on = elocker has power
    - front camera switch off + elocker switch on = elocker has no power
    Doing this I have very less chance running elocker by accident.
    Known problems-
    When I checked few years back the shop said if I roll back with elocker and go forward it might get unlocked and have to turn off and back on to re-engage. Not sure if this problem was corrected.
    Cost-
    Around 2020 the total cost was around 1500. So to me it make sense as it's for just in case type of need. I may never use as I don't do any hard trails. Maybe useful for my favorite winter wheeling.
    Haven't seen a proper trail for a 1 YEAR now...!! F#%%$@^...!!!:mad::(:frustrated: Maybe next year mom will let me and elder kiddo hit some trails, while mom take the little one go to the park.:D
    djwantke and Harringbr99 like this.
  12. Nov 26, 2023 at 12:58 PM
    nova
    nova New Member
    mike
  13. Nov 26, 2023 at 2:53 PM
    JohnD
    JohnD New Member
    I added ARB front and rear to my SR5. I haven't used to the front except exercising it. The install is beyond the average home garage tinkerer. In a way I wish I would have gone with the prebuilt third member so I could easily swap back to stock if I ever felt the front locker would a problem. Doing so also is big step toward lower gears. My only reservation about the front locker is the possibility that the locker could be engaged by a curious driver while the vehicle is moving and not in 4WD. Locking would cause the front carrier and drive shaft to be suddenly brought up to speed with potentially negative results. Some sort of electrical interlock that would only allow front locker after 4WD is fully engaged would be smart.
    I bought a complete HD rear axle for my Jeep from ECGS. I am 100% satisfied with purchase. Well made, quiet, brand new, heavy duty.
  14. Nov 27, 2023 at 10:44 AM
    Yamahamer
    Yamahamer New Member
    Nevada
    2022 4Runner Off Road
    No experience with the Eaton E-locker so can't comment on it. But I had ARBs installed in front and rear axles in my van 14 years ago - and I use them regularly. Had no problems whatsoever.
