Dual USB Power Port - Toyota (PT976-03201
Discussion in 'Audio & Video' started by BobbyC, Apr 24, 2023.
  1. Apr 24, 2023 at 11:45 AM
    BobbyC
    BobbyC [OP] New Member
    4runner TRD Premium
    Has anyone upgraded the 12 volt outlet under the head unit to the toyota part number above. I have a 2023 4runner TRD Premium? If so, can it be plug and play?
  2. Apr 24, 2023 at 1:10 PM
    JP_CO
    JP_CO New Member
    Justin
    2023 Silver ORP
    I have the part on order right now. From everything I've see it is a direct plug and play replacement for the 12v plug.
  3. Apr 26, 2023 at 5:20 PM
    JP_CO
    JP_CO New Member
    Justin
    2023 Silver ORP
    I just installed the dual usb power port last night, it is plug and play. It took me about 20 minutes total time to get it in.
    I think the price is worth it for the part to look factory, have the Toyota quality behind it, and be plug and play.
  4. May 9, 2023 at 11:02 AM
    22ORP
    22ORP New Member
    2022 Lunar Rock ORP
    i've had a tough time finding a dual charger that fits the slot next to the lighter. does this replace the single usb next to the lighter?
  5. May 9, 2023 at 11:15 AM
  6. May 10, 2023 at 8:10 AM
    BobbyC
    4runner TRD Premium
    The part number I listed in the title is a Toyota part number. This dual USB can be installed in the 12v charger round hole
    by the Toyota dealer and can be ordered with your 4runner. This part perfectly fits the circular 12v factory hole and plugs into factory wiring. There is no cutting or splicing the factory wiring. I do not see any reason to go to Amazon for something that does not fit perfectly. I did the install myself and my only issue was getting the 12v plug to release from the trim piece. I am very happy with the appearance and functionality.
    J31Bodie and qcTRDct like this.
  7. May 10, 2023 at 9:08 AM
    Lou
    Lou New Member
    2021 TRD Off Road Premium
    Does this replace the round 12v plug or the single USB plug?
  8. May 10, 2023 at 2:15 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Sounds like the round 12v plug
    edit:I’d like to see the single replaced with a double myself.
  9. May 10, 2023 at 2:15 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Any photos?
  10. May 10, 2023 at 2:45 PM
  11. May 10, 2023 at 4:45 PM
    Is it a plug & play part? Doesn't look like plug and play, looks like a permanent fix. It has a square cover vs the 12v circular port has a more round cover. IMO Spare Parts have a valid question. "Any photos?" to see its fit and finish.
    (If its a permanent thing) Just a thought, lucky that I didn't go for a permanent thing and I kept the original 12V circular port I was able to plug in my laptop charger while I take some meetings while waiting at the school pick up line.
  12. May 10, 2023 at 4:51 PM
    I was just answering the questions about the pic.
    Nothing about plug and play.
    kmeeg likes this.
  13. May 11, 2023 at 12:42 PM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    It fits directly into the hole left when you remove the cig lighter. I added one inside my center console and inside the glove box. The most you might have to do is splice into the factory harness if there are no wire terminals on your charger. I used part number 00016-00225.
    Spare Parts likes this.
  14. May 11, 2023 at 4:57 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    I have a 12volt plug in with 2 USB ports in there, was push it in, and done.
  15. May 11, 2023 at 9:28 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Oddly, that's among what they included with the $199 option for 2 USB ports + fast charging cables. So now including the 12V plug in the console, I can charge 5 devices at once in the front seat.:rofl:
    Spare Parts[QUOTED] likes this.
  16. Aug 6, 2023 at 5:10 PM
    T4R4Jman
    T4R4Jman New Member
    Jeremy
    2023 Limited - Nautical Blue Metallic
    Any idea why a 2023 Limited isn’t listed in the fitments? I have the kit that has the dual-port plug-in, but I’d rather have something that doesn’t stick out as much. The only thing I can think is the bezel interferes with the seat heater/cooler controls. Could someone measure the bezel height and width?
  17. Aug 6, 2023 at 5:57 PM
    TRD Ted
    TRD Ted New Member
    Mine came with it. I like not having to plug it in the center console if I don’t feel like using Apple car play like in my Tacoma.
  18. Aug 6, 2023 at 8:55 PM
    I don’t understand why these USB-power socket adapters aren’t more popular. They are cheaper and way more versatile: you can get 2 USB-A ports, or a USB-A port and a USB-C port. They can deliver more power than the Toyota part. When the next USB-standard connector rolls out, you can just upgrade for another $7. And at your whim you can pull it out and plug in your favorite 12 volt toys.
    @kmeeg how long have you had that adapter and how has it held up?
  19. Aug 7, 2023 at 3:59 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    And when I traded my Tacoma, I just switched it from that to the runner, might even say it was my first mod.
