Dropping the Pan? Tranny Fluid Drain & Fill
Discussion in '5th Gen 4Runners (2010-2024)' started by Scarif_1, Aug 16, 2024.
  1. Aug 16, 2024 at 1:06 PM
    Scarif_1
    Scarif_1 [OP] New Member
    Oakland
    2020 TRD ORP
    Coming up on my 60k maintenance interval so I got another thread going regarding coolant drain & fills. Here’s one on transmission fluid. How many of you are dropping the transmission pan with transmission fluid drain & fills? Is draining a bit more and cleaning the magnets worth breaking that factory seal around the pan? I do intend to stay on top of the 60k changes. Might even bump it down to 50k without dropping the pan.
  2. Aug 16, 2024 at 1:09 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. Custom High Clearance Fender Liners *Coming soon Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I don't think its worth it personally. You don't get much extra fluid out of the system by dropping the pan.
    Drain and fill is the way.
  3. Aug 16, 2024 at 2:15 PM
    Number16
    Number16 New Member
    2021 4runner
    When should you change the transmission filter on these?
  4. Aug 16, 2024 at 2:27 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    FWIW highly regarded Mr. Car Care Nut (Toyota Master Tech.) on YouTube says it’s not necessary with 60k drain & fill intervals.
    Number16[QUOTED] likes this.
  5. Aug 16, 2024 at 4:44 PM
    1SilverRunner
    Tejas
    It’s hardly a filter. Just a big metal screen. Similar to the screen filter on your engine's oil pickup tube.
    I don’t feel the need to change it at all
  6. Aug 16, 2024 at 8:11 PM
    3JOH22A Toyota Gigolo
    In the distant future, the factory FIPG seal will leak, usually by rust jacking on the steel pan flange. You can drop the pan and replace the filter then. No need to do it sooner.
    Scarif_1[QUOTED][OP] likes this.
  7. Aug 16, 2024 at 9:03 PM
    Scarif_1
    Oakland
    2020 TRD ORP
    FIPG “Factory Installed Pan Gasket”? California truck here so that rust might be in the very distant future. Nonetheless I’ll leave well enough alone and just do a simple drain & fill at 55k. No need to be more invasive than necessary I’m hearing. Thanks for the input everyone.
  8. Aug 16, 2024 at 9:13 PM
    ^FIPG - formed in-place gasket. It's a liquid gasket that is typically robotically injected onto the pan at the factory. After installation, the liquid cures to a solid.
  9. Aug 19, 2024 at 7:27 AM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    No fuck that. The gasket looks abit tricky due to size. I am not sure theres great value in dropping the pan, cleaning magnets or filter. Better to just drain and fill, but use the temp and overflow plug method to ensure correct level on volume. Youll need scan tool as the thermocouples or IR gun seem a few degrees off in readings and when the temp window is so narrow for volume check..use the right scan gauge to check it.
    1SilverRunner likes this.
  10. Aug 19, 2024 at 7:57 AM
    I flush using the internal pump and the bucket method.
  11. Aug 19, 2024 at 1:53 PM
    like2lean
    like2lean New Member
    Agree, if that screen ever gets clogged enough to need replacing it's going to be from bits of your trans, so a fluid service is the least of your worries.
  12. Aug 19, 2024 at 5:22 PM
    Rupp1
    Rupp1 New Member
    NC
    2017 SR5 Premium RWD Starlight Black
    Drain and fill only unless you’re having issues.
  13. Aug 21, 2024 at 3:49 AM
    golfpilot
    golfpilot New Member
    David
    Switzerland
    How is this done?
    How much fluid does it get out compared to the usual draining?
  14. Aug 21, 2024 at 6:51 AM
  15. Aug 21, 2024 at 10:22 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Not needed and especially if you live in rusty land. Break a bolt off and your in for a pain in the rear. Drain and fill, done.
